Old 03-15-2011, 06:02 PM   #1
Question
can i install solid bamboo over sheet vinyl on concrete?
if it can be done .. should i float or glue? i think float but do not want floor to "move" or be wavy... or if it even would?? would vinyl act as moisture barrier? or still lay paper?
thx
KrispyDIY is offline   Reply With Quote
Old 03-15-2011, 08:39 PM   #2
woodman58's Avatar
I would only float this floor. By glueing bamboo to the vinyl, you have to trust that it is secure enough to the floor. Without pulling it up you will not be able to tell if they used unough or the right type of glue to keep the old floor secured for life the life of the new bamboo. With the vinyl you will not need a moisture barrier.
woodman58 is offline   Reply With Quote
The Following User Says Thank You to woodman58 For This Useful Post:
KrispyDIY (03-21-2011)
Old 03-21-2011, 04:46 PM   #3
thanks woodman58... so float on vinyl but what about glue board to board? How does it keep from spreading apart?
Old 03-21-2011, 05:37 PM   #4
Cool
I agree that it would be good to do a floating system, or you could nail it. If you go floating, you are normally glueing each board to the other board. Also you can keep the boards from having too much movement by putting a quality underlayment down first. Such as a rubber and that will make it feel like a soild glue down installation without the need of nailing or glueing it down.
IceT is offline   Reply With Quote
Old 03-21-2011, 06:45 PM   #5
Question
hey IceT
wondering what you mean by nailing it... board to board? or into concrete.? now the sheet vinyl would be the "rubber underlayment" is that what you mean?
Old 03-21-2011, 07:21 PM   #6
You can lay down a plywood sub-flooring and nail into that. Sorry I didn't mention that part.
For the Rubber underlayment, that is a foam or rubber that is designed for floating systems. I recommend the rubber if you want the best type of walk. The cost is a bit more than foam (about $2 sqft vs 0.75 sqft for the foam), but you will thank me later.
Old 03-21-2011, 09:00 PM   #7
woodman58's Avatar
You can glue board to board if it is a locking system.I'm not sure how well it would hold together if it is tounge and grove.
Old 03-21-2011, 10:20 PM   #8
thanks IceT, if i were to add the plywood then yes i would definitely nail it but my whole question was can i install over the sheet vinyl and use vinyl as the barrier like woodman58 commented.. so instead of "rubber" use the vinyl??
its not locking so i was a little wary of glueing board to board floating or not....
so still a little confused...
Old 03-22-2011, 06:36 AM   #9
woodman58's Avatar
There are some woods that the T&G can be glued together. I have not worked with them. Have you checked with the manufacturer? They will be the best source for this info.
Old 03-22-2011, 02:29 PM   #10
thanks woodman58
Old 03-22-2011, 03:51 PM   #11
If you float the floor, you would need a foam or rubber to under the floor. So you will need something more than the vinyl if you are going to float it.
Old 03-22-2011, 04:24 PM   #12
the vinyl is foam (spongy) and 1/16" thick .. that okay?
Old 03-22-2011, 05:03 PM   #13
Wood Worker
RiverOaks's Avatar
Vinyl sheet flooring can not be used in place of the foam underlayments needed for a floating system.
RiverOaks is offline   Reply With Quote
The Following User Says Thank You to RiverOaks For This Useful Post:
KrispyDIY (03-22-2011)
Old 03-22-2011, 05:48 PM   #14
If it is a straight tongue and groove (like almost all solid flooring is), you do NOT want to float that. The only flooring that should be floated is that which has a lock mechanism rather than a straight tongue and groove. Like the picture below.
Buy a lock together bamboo made for floating, and lay it over the vinyl with a layer of laminate underlayment in between. No other method will be recommended.
Mikef5000 is offline   Reply With Quote
The Following User Says Thank You to Mikef5000 For This Useful Post:
Old 03-22-2011, 05:49 PM   #15
Picture error in the above post. Here it is again:
Need to Install Hand Rail on Basement Stairs, but on Concrete Wall Firehawk734 Building & Construction 40 01-18-2012 09:33 AM
Tiling over sheet vinyl frskelly Flooring 9 11-07-2011 11:54 PM
Concrete prep prior to vinyl install Norm.Hummel Flooring 0 07-05-2010 09:29 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 01:04 PM
Tile on concrete slab, ground level - bamboo? IvoryRing Flooring 2 06-28-2006 09:52 AM
