Old 08-19-2008, 05:19 PM   #1
Can I install Lam Flooring without clearing room?
Planning on installing Quick Step Lam Flooring in 2 story unit condo/townhouse, 1st level living room over concrete above grade slab and 2 bedrooms on 2nd level wood sub floor. The place is around 1000sf. I'm living in the unit while remodeling and don't have place to store 2nd floor larger furniture to clear rooms.
Is there a reason from a risk of faulty installation point of view that I can't shove the furniture to one end of the room, lay the lam flooring up to the furniture, then move the furniture onto the area I just laid the lam flooring, then finish laying flooring on remaining area?
Any thoughts advice appreciated.
gmhut is offline   Reply With Quote
Old 08-19-2008, 05:59 PM   #2
That's what I did when I put it in our "home office." Did not want to disassemble the Computer Desk, so I decided where I was going to start, moved the big furniture to the opposite side of the room and started laying the floor on the "uncovered" section. Laid it up to the furniture, moved the furniture onto the laminate and continued laying the floor. Been three years and no problems. Laid over concrete.
Mickey53 is offline   Reply With Quote
Old 08-21-2008, 10:23 AM   #3
Yes you can, I've done many that way. Just protect the new floor when moving the furniture, especially the edge, take a piece of scrap and fit it in where you move the furniture so you don't take a divot out.
Zero Punch is offline   Reply With Quote
Crazy?....but how do I install hardwood flooring on wall yummy mummy Flooring 37 01-08-2009 06:19 PM
New Laminate Flooring In Living Room zmurphy Project Showcase 9 05-07-2008 12:15 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 06:34 PM
Laminate Flooring Flowing from Room to Room frskelly Flooring 1 09-16-2007 12:14 AM
