Can I Glue Down Bruce Lock And Fold? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-01-2012, 08:38 AM   #1
Can I glue down Bruce Lock and Fold?
I purchased and installed a 3" Bruce Lock and Fold Engineered wood. The noise is driving my wife crazy. The concrete subfloor was level, I left expansion joints. I just think it is the nature of floating floors to have some give and to make noise.
Can I pull them up and reinstall using glue? I know it is ideally meant to float, but the installation guide does include instructions for using glue.
Thanks.
bigjwood is offline   Reply With Quote
Old 06-01-2012, 08:41 AM   #2
Rewards Points: 13,300
What did you put under it for a vaper barrier?
Old 06-01-2012, 08:44 AM   #3
A basic foam underlay with vapor barrier.
I used a basic foam underlay with vapor barrier. The subfloor is concrete slab.
Old 06-02-2012, 06:47 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
We've sold the Bruce lock and fold products before. We dropped them pretty quickly because every job had noise issues. It's not floating floors in general that do this. It's this specific product that is having issues. If the back is real wood then it should accept an adhesive. We've seen guys glue this stuff down for the same reason and never have any issues. Another option is to just glue the joint itself. Fill it with bead of laminate glue and snap it back together. When it sets you won't have any more movement in the joint, which is where the noise comes from.
Darkling Designs
poppameth is offline   Reply With Quote
Old 06-02-2012, 06:56 AM   #5
Thanks Poppameth. BTW, I'm just over the mountain in Charlottesville.
Old 06-03-2012, 12:14 PM   #6
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
If you need us to come fix it let us know! I'm at Morris Paint in Staunton. We can send someone to look at it and determine what the actual issue is if needed.
Darkling Designs
Bruce Lock & Fold engineered hardwood? zel Flooring 102 01-30-2013 12:31 PM
Unsure about my new lock & fold floor pr57001 Flooring 0 12-15-2009 09:42 PM
Cabin grade vs 1st quality Bruce Lock N Fold Treasures Flooring 4 09-12-2009 11:03 PM
Ripping up Bruce Lock and Fold HELP!! gina05912 Flooring 5 06-15-2009 08:59 PM
Bruce lock and fold flooring vs pergo 2goresmom Flooring 2 06-15-2009 08:51 PM
