Can I Get Away With Not Sanding These Floorboards? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 07:55 AM   #1
Can I get away with not sanding these floorboards?
Hi guys, I'm hoping to avoid sanding these floorboards before I stain dark and varnish. Would it work or would it look awful?
Is there a way to clean the boards a little without fully sanding?
Picture below:
Thanks for reading.
xandos159 is offline   Reply With Quote
Old 02-12-2012, 08:07 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Stain and varnish an inconspicuous area, like a closet, and see what your results are.
But some extra elbow grease now will net you so much better results for years to come.
titanoman is offline   Reply With Quote
Old 02-12-2012, 08:19 AM   #3
the Musigician
DangerMouse's Avatar
If there is ANY old urethane/aluminum oxide/wax on the floor, stain will not penetrate and varnish will not stick.
I'd sand the whole thing to properly prepare the surface for stain and varnish..
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
framer52 (02-12-2012)
How thorough the sanding on deck? Hossenfeffer Painting 2 06-17-2011 06:47 PM
Car Painting and sanding h3llfir3 Painting 19 08-11-2009 09:44 PM
Car Painting and sanding h3llfir3 Automotive Repairs 1 08-10-2009 10:02 PM
sanding vs liquid sander for high gloss egzh Painting 5 06-25-2009 06:59 PM
Sanding marks.......will they show yummy mummy Building & Construction 9 07-23-2008 11:43 PM
