It's been sitting in the cartons in my house for the last two years as I finish some remodeling. But my rooms are fairly small, so I think 72" lengths may not look good?
Is it okay to cut each piece down to smaller sizes and install them like that? Or does that introduce problems? I know nothing about flooring, btw. I'm just a fearless DIY'er.
Btw, is it bad to leave the cartons stacked up on each other for two years? It's been inside my heated/air conditioned home.
I don't see a problem with 6' lengths even in a small room. How small is it anyway and what kind of room? I would not cut the planks. You'll lose the t&g and any micro bevel the wood has. Leave it alone.
Storing it in a conditioned space is the right thing to do.
I've never laid floor before. I will have to cut the ends off lots of planks to get them to fit. Figured there would be a lot of leftover cut plank that I might not be able to use?
You would have to be able to cut a proper tongue and groove on the flat ends to install it if you cut it all to down to 36". It's unlikely your have a way to do this effectively.
You could start with a full plank at a wall less 1/4" for expansion. Continue adding planks to the far end of that row of planks. Cut off what you don't need of the last piece and make the last piece fit to the wall, less 1/4".
THEN, use that cut-off to begin your next row. Basically you are wasting nothing. This will cause all plank-ends to be located randomly throughout the floor. This ia usually the way it is done.
This is basic, but it's the way it works. You don't have to make any tongue and groove cuts at all.
Thanks for explaining how it works, Bud. I haven't gotten that far yet, obviously.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
