Can I cover old cracked vinyl flooring with lauan and new vinyl?
As long as there is no structural issues causing the old vinyl to crack there is no reason why not. You say no glue vinyl. If you are just laying sheet goods you will be fine but if using peal and stick tiles don't use luan. Use a 1/4" plywood. Luan has oils in it that will not allow the tiles to bond well. Also fill any voids from the screws or they will show through the vinyl.
Minichillo's Construction
I will never leave you hanging!
