Can I Ceramic Tile Over Linoleum? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-10-2006, 11:21 AM   #1
Question
Can I ceramic tile over linoleum?
I have a cement floor in my kitchen w/ linoleum over it. I'd like to tile over the linoleum versus trying to pull up the old floor. If that won't work what's the best way to pull up the old? I laid that with adhesive a couple years ago. Hope someone can Help! Thanks in advance.
signed- havetime.
havetime_4fun is offline   Reply With Quote
Old 08-10-2006, 12:32 PM   #2
vinyl tile
or ceramic tile?
redline is offline   Reply With Quote
Old 08-10-2006, 01:49 PM   #3
Sorry,.
I'll be installing ceramic tile.
Old 08-10-2006, 02:44 PM   #4
renovations
No you cannot lay ceramic tile over lino. When you put the lino down did you use some sort of underlayment? Like 1/4" particle board or plywood? If so the easiest way to get up the lino is to pull the underlayment. Then you likely need another layer of plywood, then cement board and then tile.
Bonus is offline   Reply With Quote
Old 08-12-2006, 03:09 PM   #5
Rewards Points: 297
I took up a linoleum kitchen floor a couple of weeks ago. I used 6" ice scrapper and it came up very easily. The floor was 26 years old, so maybe that had something to do with it, as it the glue was very brittle and would break up easily. The 1/4" masonite beneath the lino was a very serious pain to take up though.
I've seen several cases where people have tiled over existing lino and vinyl, so if I wouldn't say it *couldn't* be done (if the lino is in good shape, but if it is then why are you replacing it?), but I woundn't recomend it.
Bonus, I don't see why you are laying plywood and cement board down. Assuming his concrete floor is in good shape (flat, no active cracks) I think you should be able to tile directly over that (with some sort of vapor barrier).
LanterDan is offline   Reply With Quote
Old 08-13-2006, 12:25 AM   #6
747
registered
747's Avatar
Rewards Points: 534
If he has a cement floor. Best ways is to get down to cement. Then spread some kind of thinset or something you guys no what i mean over that cement floor and lay the cement board over the thin set or thick set before it sets up than mesh the seams then slap some thin set or something over the mess tap let dry then your ready for tile and acourse the thin or thick set of your choice. That is the a experience tile guy would do it. Oh and acourse screw down that cement board.
747 is offline   Reply With Quote
Old 08-13-2006, 02:07 AM   #7
renovations
Lanterdan, mea culpa, missed that in the post. No ply/cbu nec.
747, where you bin? We missed ya.
Old 08-13-2006, 07:21 PM   #8
NO CBUs over concrete.
R&D Tile is offline   Reply With Quote
Old 08-13-2006, 08:52 PM   #9
747
registered
747's Avatar
Rewards Points: 534
I just seen them do it like that on hometime 5am saturday morning. I guesss they didn't do it rite.
Old 08-21-2006, 06:01 PM   #10
Ms Jay
msjay2u's Avatar
why do you even have to put a sub floor down? I ripped up the linoleum in my kitchen and applied the tile directly to the cement slap floor and it came out wonderful. I did this in my kitchen and my patio.
msjay2u is offline   Reply With Quote
Old 09-12-2006, 01:54 PM   #11
Although it is not recommended, it is possible to lay over lino if you are sure the lino is solid. It is always best to remove the lino to prevent the possiblity of the tiles coming up over time. However I have been remodeling homes for over 23 years and have consistantly layed tile directly to concrete floors using only thinset and have NEVER had any problems, all my floors have stayed just fine and as I guarantee my work always, it is not in my best interest to do shoddy work. Forget all the extra underlayment it is not needed. Follow the KISS procedure : Keep It Simple Stupid.
Tony1963 is offline   Reply With Quote
Old 09-12-2006, 11:15 PM   #12
Floorwizard's Avatar
I agree with that when used with reference to "work smart not hard".
But it just seems to me that installing over lino or installing over concrete without an anti fracture membrane is just a bigger risk. A risk I personally would not make it my own home.
Mostly because I would always be waiting for the grout to crack, or the slab to move.
Floorwizard is offline   Reply With Quote
Old 09-14-2006, 09:47 PM   #13
Middle aged floor guy
Donedat's Avatar
Shouldn't be too hard to remove the linoleum. There has to be a loose corner somewhere on the floor where you can grab hold of a pull.
Donedat is offline   Reply With Quote
Old 01-22-2008, 12:47 AM   #14
Grammatical Correction:
You mean you recently SAW this task perfromed on HomeTime at 5am Sat morning and you are assuming they didn't perform it correctly.
MikesterSTLMO is offline   Reply With Quote
Old 01-23-2008, 11:34 AM   #15
Definately SAW it because the post is way old
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 06:19 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
How do I remove this ceramic tile? tripower Flooring 5 07-23-2007 09:45 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 02:26 PM
