Can I Ceramic Tile On To Linoleum? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-21-2011, 09:32 AM   #1
I have a bi-level home which is only 9 years old and has a linoleum kitchen floor upstairs. The linoleum is in good shape its just do for a change. I plan on using 20 inch plus ceramic tiles (so big tiles, not sure if this matters). Under the floor would be just plywood, so if I can't lay the tile on the linoleum, would I have to lay down cement board down? The floor is level and smooth so there is no worry of things being uneven or having dips. The issues are raising the floor to much in comparison to the adjacent room, and of course to see if I can save a little money without effecting the outcome of the job. I know the right way is to take it out and lay a cement board down, just curious if anyone has had any success doing it this way.
Thanks so much.
Bryan
Sent from my HTC Evo using DIY Chatroom
brycom is offline   Reply With Quote
Old 02-21-2011, 09:58 AM   #2
Coatings Nerd
Rip it out, its not that hard. Then thinset, cement board, and tile.
Evenness has nothing to do with weather or not you lay cement board. You need to take the movement out of the wood. Tile doesnt move, when it moves they break, or the grout cracks and crumbles.
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 02-21-2011, 10:38 AM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 146
You also need to know how thick the plywood. CBU adds no structural strength.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-21-2011, 11:34 AM   #4
Civil Engineer
Rewards Points: 4,856
20 inch tile is large format, and requires a much stiffer floor (measured by the L/D ratio) than smaller tile to prevent cracking of the tile. For a detailed discussion about floor stiffness and how to determine how stiff your floor is, see www.schluter.com
Schluter makes ditramat, which is a bond breaker commonly used to reduce the potential for tile cracking. Regardless whether you use their product or not, you absolutely need to determine the stiffness of your floor, which is a function of the size of joists, the span of the joists, the spacing of the joists, the load on the joists, and the type of subfloor you have. Floor stiffness is not affected by installation of cement backer board, so if your floor is not stiff enough for 20 inch tile, you need to develop a plan to increase the stiffness, else you should consider using a smaller format tile. The penalty for installing a large format tile on a floor which is not stiff enough is cracked tile, cracked grout, or both.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Tom Struble (02-21-2011)
Old 02-21-2011, 01:29 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I know the right way is to take it out and lay a cement board down...
Well then?
XXX
Old 02-22-2011, 03:59 PM   #6
Thank you all for your response, I am going to rip it out and lay cement board down.
Old 02-22-2011, 07:41 PM   #7
On a concrete floor you can .
fabricator is offline   Reply With Quote
Can I ceramic tile over linoleum? havetime_4fun Flooring 20 12-30-2011 06:29 AM
ceramic tile over linoleum Devyn Flooring 8 03-17-2011 04:33 PM
Old linoleum and new ceramic tile tmramrod91 Flooring 0 07-25-2010 07:39 PM
lay ceramic tile over linoleum lynette Tiling, ceramics, marble 3 07-16-2010 06:12 PM
Ceramic tile over very old linoleum? jrdamien Flooring 1 10-19-2009 05:40 AM
