Can Hear Seam Tape Crinkling Under New Carpet Install? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-22-2012, 01:33 AM   #1
Can hear seam tape crinkling under new carpet install?
Hi all,
New member here with a question. We just had new carpet installed with a 6lb. 7/16" pad (no waterproof layer). On certain seams throughout the house we can definitely hear what appears to be the seam tape crinkling. While we have other issues with the install job, I was wondering if the seam tape noise was either a. normal or b. easily fixed?
Thanks in advance!
Lumpia is offline   Reply With Quote
Old 08-22-2012, 01:36 AM   #2
Rewards Points: 13,274
Not suppost to hear it.
Old 08-22-2012, 07:20 AM   #3
Too Short? Cut it Again!
If you are hearing the thermal carpet seaming tape giving way it was either applied at too low a temperature and did not bond with the carpet backing and/or the installers have over-stretched the carpeting and to the point it is being overly strained.
If it is the tape, the situation will probably not get better and if it gives completely you will start loosing seams completely. No real way I know of to fix it from above.
You mentioned other install problems. It sounds like you need to call the folks back.
Old 08-22-2012, 01:07 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Unless they used a Kool Glide iron, the carpet will need to be layed back to replace the seam tape.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Flooring Under Carpet Mstrenke Flooring 4 06-24-2012 06:54 PM
carpet install problem plummcrazy Flooring 1 04-15-2008 01:42 AM
Carpet installation on Dricore Cyrus Flooring 8 03-24-2008 10:14 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
