Can A Ditra Mat Be Glued To Gypcrete? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-15-2008, 08:28 PM   #1
Can a Ditra Mat be Glued to Gypcrete?
I'm well advised of the shortcomings of gypcrete--->mortar doesn't adhere to it....modified mortar takes eons to set, blah, blah, blah.
Can a Ditra Mat successfully be glued to gypcrete? The old lino (aka vinyl) was glued and took the best of my shoulder to remove. Why not Ditra?
Janet is offline   Reply With Quote
Old 08-15-2008, 09:58 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
Hello again Janet,
Go to Schluter's Ditra Handbook and find page 11. http://www.schluter.com/media/brochu...k-2008-ENG.pdf
Jaz
Old 08-16-2008, 12:05 AM   #3
Thanx for the site though to the best of my ability, I'm not sure I can decipher it. To the best if my knowledge, the problem with gypcrete is that it's too dry and will suck up the moisture from anything on top of it and thus prevent any mortar from curing properly. And -->the gypcrete is bone dry (which runs contrary to one of the reasons identified in the Schulter propaganda to use it in the first place).
All I want to know, is whether a Ditra mat can be successfully glued to gypcrete like the old vinyl was and porcelain tile layed atop-->with mortar.
This is completely foreign to me and I'm tapping as many resources as I can to avoid mistakes.
Thank you all for your patience and tolerance.
Old 08-16-2008, 08:59 AM   #4
JJC
Pro
Janet, If you are still having problems understanding the info, then the next logical step is to call them direct at their 800 number. The only place I know of to get correct info regarding a product is from the manufacturer. Who else knows the product better than the maker of the product?
JJC is offline   Reply With Quote
Old 08-16-2008, 09:01 AM   #5
K&B Remodeler/Tile Guy
angus242's Avatar
Schluter's instructions are pretty clear:
"By addressing all of the challenges associated with today’s fast, lightweight construction methods, Schluter®-DITRA provides a durable
installation system for ceramic and stone tile over gypsum substrates.
Thinset for Ditra to gypcrete and then tile to Ditra:
"Setting and Grouting Materials
unmodified thin-set mortar – ANSI A118.1
grout – ANSI A118.3, A118.6, A118.7,
A118.8"
For that type of thinset, I use Mapei Kerabond. Also frequently used is Laticrete 317.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 08-16-2008, 10:06 PM   #6
Thank you one and all----> And I promise to never again mention the dreaded "G" word on this forum ever again.
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
What Does Gypcrete Look Like? Janet Flooring 1 08-05-2008 09:51 PM
Laying Porcelain Tiles Over Gypcrete @ Lino Janet Flooring 11 07-30-2008 04:38 PM
To Ditra or not? JamesEric Flooring 20 02-24-2008 10:42 AM
glued down carpet...can I cheat? Dusty Flooring 3 10-10-2006 05:18 PM
