Can Bamboo Be Refinished - Flooring - DIY Chatroom Home Improvement Forum
Old 05-19-2011, 08:29 PM   #1
can bamboo be refinished
I am looking into getting some bamboo flooring. They only come in prefinished with aluminum oxide.
I am curious, later down the road, if I need to refinish the flooring, can it be done? I've been told its the same process as refinishing standard hardwood floor. Is that true? Can you use polyurethane on bamboo? How about staining?
Is it possible to refinish with the same aluminum oxide?
I am leaning towards strand woven carbonized bamboo 5/8" if I do bamboo at all. Other bamboo construction is too soft (so I hear). Otherwise, I'd rather go with standard hardwood.
acerunner is offline   Reply With Quote
Old 05-19-2011, 09:53 PM   #2
is this solid bamboo or engineered? 3/4 solid wood can be finished approx 4-5 times, engineered maybe 2-3. it depends on how much you have to sand off when its refinished. how much a foot is bamboo going for nowadays. I would steer away from LL for flooring.
Old 05-20-2011, 01:10 AM   #3
This is solid. I was quoted $3.50 per sq ft. what is LL?
Old 05-20-2011, 06:59 AM   #4
Lumber Liquidators
Old 05-20-2011, 07:48 AM   #5
woodman58's Avatar
Most bamboo is from 3/8" to 5/8" thick. You can sand and refinish it. It can be stained. Bamboo is harder than oak. Aluminum oxide is a finish put on at the manufacturer. You can put on finishes harder than poly.
woodman58 is offline   Reply With Quote
Old 05-20-2011, 03:45 PM   #6
any suggestions that work well with bamboo?
Old 05-21-2011, 05:57 AM   #7
woodman58's Avatar
Try this site
http://www.trustorcoatings.com/pages...mic_finish.php
Old 05-23-2011, 12:27 AM   #8
I have only refinished one bamboo floor so far and it turned out good. It is very hard, so it is pretty difficult to sand, but you can do it. I suggest Bona traffic finish.
RhodesHardwood is offline   Reply With Quote
To use, or not to use Bamboo... dmcandy Flooring 10 08-23-2012 12:19 PM
Bamboo Flooring Installation - subfloor question Shazza Flooring 5 03-19-2011 01:34 PM
refinish bamboo? racebum Flooring 0 07-23-2010 03:08 AM
Bamboo over Hydronic Radiant Heat SusieQ2010 Flooring 0 06-16-2010 03:47 PM
Solid strand woven bamboo in a basement? Seattle_Chris Flooring 1 05-17-2008 11:01 AM
