-   -   can bamboo be refinished (http://www.diychatroom.com/f5/can-bamboo-refinished-104986/)
acerunner 05-19-2011 09:29 PM
I am looking into getting some bamboo flooring. They only come in prefinished with aluminum oxide.
I am curious, later down the road, if I need to refinish the flooring, can it be done? I've been told its the same process as refinishing standard hardwood floor. Is that true? Can you use polyurethane on bamboo? How about staining?
Is it possible to refinish with the same aluminum oxide?
I am leaning towards strand woven carbonized bamboo 5/8" if I do bamboo at all. Other bamboo construction is too soft (so I hear). Otherwise, I'd rather go with standard hardwood.
DannyT 05-19-2011 10:53 PM
is this solid bamboo or engineered? 3/4 solid wood can be finished approx 4-5 times, engineered maybe 2-3. it depends on how much you have to sand off when its refinished. how much a foot is bamboo going for nowadays. I would steer away from LL for flooring.
acerunner 05-20-2011 02:10 AM
This is solid. I was quoted $3.50 per sq ft. what is LL?
DannyT 05-20-2011 07:59 AM
Lumber Liquidators
woodman58 05-20-2011 08:48 AM
Most bamboo is from 3/8" to 5/8" thick. You can sand and refinish it. It can be stained. Bamboo is harder than oak. Aluminum oxide is a finish put on at the manufacturer. You can put on finishes harder than poly.
acerunner 05-20-2011 04:45 PM
any suggestions that work well with bamboo?
woodman58 05-21-2011 06:57 AM
Try this site
http://www.trustorcoatings.com/pages...mic_finish.php
RhodesHardwood 05-23-2011 01:27 AM
I have only refinished one bamboo floor so far and it turned out good. It is very hard, so it is pretty difficult to sand, but you can do it. I suggest Bona traffic finish.
