Bumps In Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 03-12-2009, 09:10 AM   #1
Bumps in concrete
I am finishing my basement. I want to put laminated flooring on part of the basement and 12' vinyl tiles on some. I have noticed a couple of small bumps, or high spots in the concrete. They are barely noticeable when looking at the floor, but are very noticable if you lay a level across them. They are perhaps 4-5 inches around, rising to perhaps 1/4 inches. I tried using my belt sander with a 50 grit belt and it only scored the surface. Can I get a belt that will flatten these bumps? What else can I try?
Woodcutter is offline   Reply With Quote
Old 03-14-2009, 05:50 PM   #2
Basements usually have a pretty high moisture content in the concrete.
Do a cheap moisture test. Tape down one or more 2'x2' sheets of clear plastic (duct tape the whole perimeter of the sheet). Wait a week. If the concrete turns dark and/or beads of moisture build up on the plastic, don't do laminate.
As far as lumps in concrete go, I like a 40lb demolition hammer... If you don't have one, a short-handled sledge hammer (3lb or so) and chisel will do the trick, albeit more slowly. Basically, you chip the lump into a depression and float it level with the rest of the floor with some patch after you're done.
Mudd is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
