Bump In Underlayment - Flooring - DIY Chatroom Home Improvement Forum
Old 02-02-2008, 06:40 AM   #1
Bump in underlayment
I laid 2 layers of 1/4" dura board over 3/4"rough sawn sub floor. Used thin set between each layer.After laying out the initial pattern I noticed a slight unevenness(1/8" to 3/16") in a few 18"x 18" tiles I am installing.Can I just go with thin set to level it all out with out any cracking of tiles in the future? Thank you in advance.
mark942 is offline   Reply With Quote
Old 02-02-2008, 11:31 AM   #2
Tileguy
JazMan's Avatar
Rewards Points: 290
Mark,
Too bad you didn't ask questions before you started instead of now.
What you've done so far is wrong.
First you NEVER install any CBU direct over plank subfloors. You should have install plywood first then your 5/16" thick Durock.
The substrate has to be very flat for tile, especially with large tiles like that. You're always going to have some lippage, but 1/8 or 3/16" is a lot! Thinset can be used to fix a small area, but not an entire floor. Depends if you have one small depression or a peak.
If you can get the floor flat by using SLC's or Portalnd based patching cements, AND if your subfloor framing is up to speed for tile, I might say just go ahead anyway in spite of the lack of proper underlayment? (at your risk of course)
The basic standard for floor flatness is within 1/4" in 10 ft, AND 1/16" in 12" of required plane. With large tiles like yours I would like within 1/8" in 10 ft, especially if the tiles are smooth and shinny. You also need special thinset, not your basic stuff.
Go measure and tell me: the type, size, species, grade and the unsupported span of the joists. Also when was this house built and where is it?
Jaz
Old 02-02-2008, 02:18 PM   #3
Figures I did it wrong. I was told to do it this way in a home depot seminar. When I was told this I had to ask twice just to make sure I understood. My own thoughts were to use 5/16 plywood, then use the good old cement board or ( Wonderboard) for my underlayment. As to my Joists. 12" OC rough cut 2" x 12" # 1 Pine. The span to bearing wall is 12`. House was built in 1981,,,,,,Hence the #1 Pine. The bump I am talking about is just one tile. The rest of the tiles seem to be laying flat. My question has been answered by you with the mention of @ own risk. The thin set I am going to use is #2 modified. Longevity I guess will be time telling. Thank you again. (Pennsylvania)
Mark
Old 02-02-2008, 03:54 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 290
Mark,
Attending a 'How-To Class' at one of those big box stores was your first mistake. You have to know what you're talking about to teach others. This is true in MOST cases with tile, not too sure about other classes?
I don't know what #2 thinset is. You should be using a medium-bed thinset mortar with a large notched trowel, maybe 1/2x1/2 or larger? What brands of thinset can you get? Are you going to the orange place again? Aren't there any real tile shops near you?
Jaz
Old 02-02-2008, 04:29 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I suspect the "#2 thinset" he is referring to is the Custom brand thinsets labeled for Home Depot's use. #1 is prep goods, #2 is thinsets, #3 is grouts, some dumb stuff like that!!!
Old 02-02-2008, 07:14 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 290
You're right Bud, I remember the numbers now. Thought maybe he escaped from the orange place and went to the red-vest place and was using UltraFlex 2?
Jaz
Old 02-07-2008, 06:18 AM   #7
Flexbond thin set which is fortified is what was suggested for me to use.Dura board is the underlayment I was also directed to use.All of which is new to me.Cement board and medium bed thinset is what I am familiar with.Thats use with 2 tile floors I have done in the past.Thought I would get past the "Teach a old dog a new trick" statement.Framer by trade here gents,by the time tile gets in a building I am 1/2 way through another job........ So now I am sitting here with thinset not worthy,underlayment that doesnt level out the floor,1/8 to 1/4 notched trowels,Which are to small and a Wife that is wondering when I am going to finish the bathroom................
Tile underlayment - mortar bed question Richo Flooring 10 01-01-2008 06:54 PM
Subfloor vs Underlayment indignatz Remodeling 6 12-01-2007 03:19 PM
Hardwood floor installation on 2nd floor - underlayment necessary? digexpressions Flooring 2 11-30-2007 11:15 AM
laminate floor underlayment installation? KUIPORNG Flooring 1 03-08-2007 06:52 PM
Underlayment for laminate dm62 Flooring 3 04-02-2005 11:56 AM
