Bullnose Won't Hide Subfloor? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-05-2008, 10:56 AM   #1
Rewards Points: 43
bullnose won't hide subfloor?
hey evryone.
my situation is as follows:
i am looking to put down new hardwood floors in a small hallway of the second floor of my parents' house. what is there now is old T&G with many large plywood patches. i'm planning on tearing all of that up and laying subfloor on the joists, and then the new T&G on top of that.
my question is regarding the top stair tread/bullnosed piece of flooring. i obviously would like the part that hangs down to completely cover the edge of the subflooring, so that when coming up the stairs, you can't see it. i was planning on using 3/4" ply for the subfloor, and i can't see how the bullnose will cover that. i doesn't seem right that i should be accomodating the entire subfloor to match what the bullnose can hide, but i can't think of any other way to hide it, other than custom making the bullnose piece.
thanks for your time, and i'm sorry if the answer is embaressingly obvious.
sonofthetonsured is offline   Reply With Quote
Old 06-05-2008, 11:03 AM   #2
I think you just want to replace the top stair riser with a wider piece, to cover the subfloor.
How much taller will the last step be compared to the rest of the stairs?
NateHanson is offline   Reply With Quote
Old 06-05-2008, 11:29 AM   #3
Tileguy
JazMan's Avatar
Rewards Points: 422
All you do is install another piece of trim under the nosing similar to this: http://www.1aflooring.com/ProductIma...ing_nosing.jpg I often use a door stop stained to match.
Jaz
Old 06-05-2008, 12:57 PM   #4
Rewards Points: 43
the extra bit of molding sounds right up my alley. thanks, jazman; and thanks, nate
Old 06-05-2008, 11:32 PM   #5
Floorwizard's Avatar
great advice Jaz
Floorwizard is offline   Reply With Quote
Old 06-07-2008, 03:13 PM   #6
Still Learning
Nate has the right idea. The preference is a clean look and not adding more trim pieces.
HardwoodGuy is offline   Reply With Quote
Old 06-07-2008, 06:22 PM   #7
BUILDER / REMODELING CONT
buletbob's Avatar
95% of the open and closed stairs case's here on long Island have a 7/8 cove moulding (oak or pine) nailed under the tread to the riser. something to think about. it will cover the subfloor.
Old 06-10-2008, 11:02 AM   #8
Still Learning
That's true Bob. Techniques can be different from one area to another. Cove is very popular in northern areas.
Old 06-10-2008, 11:28 AM   #9
Rewards Points: 43
i haven't done the floor yet, and it looks like it may get delayed further still, but for the life of me i can't think of how cove molding, stained to match, would look bad
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
Replacing my subfloor DanBress Flooring 17 02-16-2008 09:11 AM
COMPLETE subfloor removal alexschmidt Flooring 4 08-02-2005 11:15 PM
