Bullnose Tile - How To Do It? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 04:20 PM   #1
Question
Bullnose Tile - how to do it?
I have a bathroom in my house that I am working on. I've purchased some 12x12 tile that I need to bullnose for pieces that will be at the top of the shower, and on the step into the shower.
Any advice on how to have this done? The guy at Home Depot said that tile doesn't have any bullnose pieces I can purchase.
Thanks in advance
tjawed is offline   Reply With Quote
Old 05-31-2010, 04:30 PM   #2
bbo
I don't do tile work myself, but you can cut at an angle if your tile saw is able to mitre ... I've also seen a demo of a rounded edge diamond blade that cuts rounded bullnose.
bbo is offline   Reply With Quote
Old 05-31-2010, 04:33 PM   #3
I think the rounded edge diamond blade would probably be close to what I'm looking for. Is there a way to get a "half circle" and not just a quarter circle?
A cut at 45 degrees just won't work for me here.
Old 05-31-2010, 05:08 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can buy a profile wheel to make the bullnose at http://www.tiletools.com for around $160 I think. Once the tile has been profiled you will see the raw edge of the tiles bisque and that usually isn't at all desirable.
How about using a metal tile edging instead?
XXX
Old 06-02-2010, 11:51 AM   #5
gmhammes's Avatar
I would also suggest the metal edging or black, whatever matches your design.
gmhammes is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
tile threshhold to shower w/out bullnose suefoerob Flooring 2 03-14-2010 06:59 PM
Bullnose corner tile for backsplash golfgirl Tiling, ceramics, marble 5 03-05-2010 07:11 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
