Bullnose Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 03-21-2013, 07:36 PM   #1
analogmusicman's Avatar
Rewards Points: 560
bullnose tile
I want my laundry room to have a nice edge. I'll put real "bullnose" in the visible areas but in the areas that aren't seen, it seems rather a waste to use the real,purchased "bullnose" tiles. (they cost quite a bit more)
I was thinking of cutting regular field tiles to the 3" height but of course the edge won't look real good. do those bullnose blades work good? are they worth the cost? maybe I should just leave the edge on my cut tiles alone and have a square edge. any thoughts?
tnx,
analogmusicman is offline   Reply With Quote
Old 03-21-2013, 08:09 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 422
Hi Ken,
Most of the time in remodeling, the 3" bullnose is not high enough, so we usually go the cutting the regular tiles. Most porcelain tile factory edges look pretty good, just expect to get 2 pieces per full tile. Some people end up painting the tops to match the walls, usually not.
Jaz
Old 03-21-2013, 09:13 PM   #3
Rewards Points: 560
thanks Jaz. yeah I'm going to save money by not buying so many bullnose. I'll only buy for the area that will be readily seen, the rest will be cut from "field tiles". the cost is pretty outrageous for the ones you buy,like almost 3x the cost of a field tile. must be because it's hard to finish an edge or maybe they just want to "sock it to ya".
tnx,
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 02:29 AM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 12:03 PM
Bullnose Tile - how to do it? tjawed Flooring 4 06-02-2010 10:51 AM
Vertical tile on wall poolecw Flooring 2 06-01-2010 10:05 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
