#1 |
Bullnose. MAstic or Thinset.
I have just had a tile floor installed in my hallways, entry, living room and dining room. I had all the baseboards removed from the drywall before installation. Now I'm going to install bullnose all around. I'm not sure if I should use mastic or thinset and this is the reason why.
When the base boards were removed much of the paper backing to the drywall went with it and I'm concerned that the moisture in the thinset will seep into the exposed drywall material. What are the disadvantages of using mastic over thinset if any. |
#2 |
Tileguy
Use a modified thin set. It'll say modified or polymer modified or something like that. It's very common available every where. Be sure to leave the expansion space between the tiles and wall open.
Jaz
Tile 4 You LLC Troy, MI KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME! |
| The Following User Says Thank You to JazMan For This Useful Post: | Xchair (03-27-2011) |
#3 |
What do you mean by "expansion space"? Placing a grout spacer under the bullnose?
#4 |
Super Moderator
Are you talking about using bull nose as a base molding?
If so, Jazzes suggested setting material (modified thin set) is good. If the area is a dry area---tile mastic should also be acceptable.---Mike---
New members: Adding your location to your profile helps in many ways.--M-- |
#5 |
The tile floor is already down. The bullnose will sit on top of the floor as a base molding. Are there any disadvantages to using tile mastic?
#6 |
Super Moderator
No disadvantage---go for it!!
| The Following User Says Thank You to oh'mike For This Useful Post: | Xchair (03-27-2011) |
#7 |
Master of none
I believe the expansion space Jasman refers to is the space between your bullnose and the floor tile. Do not grout this space. Use a caulk. Preferrably the same color as your grout. If you grout this joint, it will very likely crack as there is almost always some movement between walls and the floor. Caulking has enough give to allow some movement without cracking!
| Display Modes | |
| questions about thinset | ponch37300 | Flooring | 16 | 03-16-2011 12:45 PM |
| ceramic tile walls with mastic | Boris100 | Building & Construction | 2 | 02-14-2011 10:39 AM |
| tile man used mastic glue on entrance to shower | keyesww | Tiling, ceramics, marble | 13 | 06-08-2010 05:39 PM |
| Mixing Mastic and Thinset in a Tile Job | smata67 | Building & Construction | 2 | 08-09-2009 11:38 PM |
| Fortified Thinset | poolecw | Flooring | 4 | 10-31-2008 08:06 AM |
