Bull Nose Stair Sagging - Flooring - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 11:02 PM   #1
Bull nose stair sagging
Have a bottom bull nose stair that is sagging. Seems that the problem may be the riser. The thread is beginning to develop a hair line crack. I have opened up the back of the stair and if anyone could please give me some idea on how I may sure up the stair. Thanks Madness
Antmadness is offline   Reply With Quote
Old 08-04-2011, 11:10 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
Could you post some pictures?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 08-05-2011, 12:19 AM   #3
with pictures
Name:  stairs_001 (850 x 638).png.jpg
Size:  31.4 KBName:  stairs_002 (850 x 638).jpg
Size:  40.7 KBName:  stairs_003 (850 x 638).jpg
Size:  36.6 KBName:  stairs_004 (850 x 638).jpg
I had to place wood under the tread to keep the stair level. The last picture is the back which as you can see is a tight squeeze (in the garage surrounded by cinder blocks.
Old 08-05-2011, 01:16 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
I really don't see a way to reinforce the step other than shims glued between the riser and tread. I don't think that will solve the cracking though. I wish I could help you but I really don't know what to tell you. I don't think you want to tear the step out and reinstall but that is the only way I know of to fix it right.
Jim
The Following User Says Thank You to BigJim For This Useful Post:
Ron6519 (08-05-2011)
Bull nose stair problem sagging Antmadness Carpentry 3 08-07-2011 03:04 PM
No bull nose available for porcelain tile I chose acerunner Tiling, ceramics, marble 13 06-10-2011 11:03 PM
Laminate Stair nose agapediy Flooring 10 04-15-2011 12:27 PM
Stair Nose Attachment - HELP! BSponz1 Building & Construction 2 01-11-2011 07:51 AM
Stair Nose Attachment - HELP! BSponz1 Flooring 3 01-10-2011 01:31 PM
