Building Up A New Floor Over An Existing Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 12-12-2011, 03:24 AM   #1
Building up a new floor over an existing floor
Upstairs i have a large living room .. has 2x12 joists running across 16in OC with OSB subfloor.
Half of the living room floor is 13in. below the other.
i want to level the floor by stacking a new floor over the lower floor.
Can i simply build a new floor atop using 2x6 joists (will support it every 32in)?
TooTired is offline   Reply With Quote
Old 12-12-2011, 07:47 AM   #2
Rewards Points: 13,750
No pictures, no way to know the spans your thinking of running the 2 X6's, no way to know how this is going to effect things like doorways, steps, trim, the distance from floor to bottom of windows.
Old 12-12-2011, 10:06 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What does that mean?
Old 12-12-2011, 11:04 AM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Never 32" o/c. Always 16, stacked over the existing 2x12's, as long as there will be support under or close to where the news joists end. It sounds like the existing joists can support the new load, depending what they're bearing on. How do 2x6 joists make up 13"?
titanoman is offline   Reply With Quote
New Floor Drain in Existing Concrete Floor JPWMU Plumbing 3 04-21-2010 05:51 AM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 06:08 PM
Tying in floor joist to existing structure hebrewdiver Building & Construction 4 05-01-2009 07:44 PM
Second floor addition over existing 1st floor. handball Building & Construction 1 02-10-2009 01:08 PM
Building Wall Over Floor bradarth Flooring 2 07-11-2005 10:15 PM
