Building Up A Concret Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 02-19-2012, 06:45 PM   #1
Building up a concret floor
I have a concret slab floor that is two levels with on side about 4" lower then the other. I want to even out the floor and install hardwood. I am getting conflicting information from contractors on the best way to do this.
Shoul I invest in concret to even out the floors?
Deborah smith is offline   Reply With Quote
Old 02-19-2012, 06:50 PM   #2
DIY staff
Rewards Points: 7,174
Wood framing will work and give you a good nailing surface for your wood floor--
How's the flooring going to be attached to the higher concrete floor?
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 05:42 AM
Building room with floor joists over slab. Moisture? FogNoggin Building & Construction 0 01-29-2011 10:00 AM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Building New floor above Foyer matgol Carpentry 2 09-02-2008 04:58 PM
