Old 09-18-2009, 11:31 PM   #1
Default Building on a floating floor
We are installing a floating floor but later plan to add a closet. This would mean nailing through the floor to create the walls. Would this cause a problem with the flooring ?
kayaker sue is offline   Reply With Quote
Old 09-18-2009, 11:36 PM   #2
poppameth's Avatar
Yes it will. You can take a circular saw and cut the wood out in the area you wish to install the closet. After building the closet you can use the wood you removed to reinstall the floor inside the closet.
poppameth is offline   Reply With Quote
Old 09-19-2009, 02:11 PM   #3
Drywall contractor
Read the instructions for the particular brand of flooring you're going to use. Every type I've installed says to leave a gap at the wall to allow for expansion/contraction. If you nail through it, it can't move with seasonal changes (heating and cooling). It could cause buckling and your warranty would be void.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-19-2009, 03:30 PM   #4
poppameth's Avatar
Yep, this is the exact reason. You'd have to cut out the floor in the area for the closet. Build your closet and make sure the wood outside of it has adequate expansion area up against your new walls. Then you can reuse the portion you cut out inside the closet you just built. You may need a transition in the doorway.
Old 09-20-2009, 03:11 PM   #5
Just what I needed to know ... thanks !
More On This Topic
How to Organize a Closet
How to Organize a Closet by Expert Village
Hi my name is Frank Clarke with Oliver and Associates Realty in London Ontario on behalf of expertvillage.com. I would like to speak with you briefly in regards to decluttering your closet space for the purpose of selling your home. This is a example of... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we will be finishing our closet. After painting the ceiling we went ahead and painted the interior our closet with a color called coconut milk. Now this is more of a neutral color that will be... Read More »
In bi-level houses, transporting soiled laundry downstairs wastes considerable effort. A simple solution is to transform a closet into a laundry chute. There's no need to give up an entire closet; a small addition against one wall can be an effective... Read More »
Hi, I'm Matt Cail and on behalf of Expert Village I'm going to show you how to add some festive decorations to your Thanksgiving Day. Let's start simple, one of the easiest decorations is something you yourself are not going to buy but rather something... Read More »
So it's winter, and your kids have nowhere to go. They're bored and they don't have their own space. If you have a closet that's not too messy--especially their own--they can empty it or shift the contents to use it as their very own clubhouse. Read More »
Floating Floor Repair justbcz Flooring 6 07-06-2009 09:13 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 02:11 PM
Floating floor installation over tongue and groove subfloor help Delairen Flooring 0 11-05-2008 03:21 PM
Floating floor over cement gwendda Flooring 4 07-18-2006 06:58 PM
Floating Floor in the kitchen sweetwillie66 Flooring 3 02-12-2006 04:10 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
