Building Codes For Subfloors - Flooring - DIY Chatroom Home Improvement Forum
Old 12-16-2012, 07:51 PM   #1
Building codes for subfloors
I am working on a bathroom remodel and I am getting ready to prep the floor for ceramic tile installation. I have removed the old tiles, mortar and cement board. Upon scrapping the remaining little chunks and verifying the floor was level, I noticed the subfloor doesn't have a single fastener holding it to the joists. Looking at the joists from the bottom side in the basement I see they used only glue. I know this is not a good practice, especially if installing tile due to flex and possible movement but is there a building code requirement to use fasteners? The floors in the bathroom, as well ad the rest of the upstairs, creek very bad as well. Could the use of only glue be the cause of this? The house was built in 1996. I ask because if it is required, I wanted to dig into how it passed inspection. Thanks
Shawn49424 is offline   Reply With Quote
Old 12-16-2012, 08:04 PM   #2
Rewards Points: 13,270
It was suppost to be fastened with screws or ring shanked nails every 6".
Also if there's going to be tile make sure there was no partical board or just 1/2 sublooring used.
Old 12-16-2012, 08:13 PM   #3
That's exactly what I thought. I had already bought extra fasteners to install to assure the floor had no chance for flexing. The subfloor is 3/4" OSB. I know this because I had to replace some of OSB where the run was due to water damage. I followed the correct procedure and used the proper fasteners for that; thanks DIY 😃. So you know if the creaking of the floor could be contributed to the use of only glue?
Old 12-16-2012, 08:20 PM   #4
Undersized floor joist, to long a span, not using T & G subflooring, not fastening can all cause it.
Old 12-16-2012, 08:21 PM   #5
Yikes, I have my hands full. Thanks for the help good sir.
Old 12-17-2012, 04:13 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 290
Yikes.......no fasteners? I wonder what other screw-ups they made?
Jaz
Old 12-17-2012, 04:46 PM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Could be FHA home. Their regs were so bad, they only required 4 nails in a 4'x8' roof sheathing. They said that the shingles would hold down the sheathing.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-17-2012, 08:19 PM   #8
Is there a way to find out if it was an FHA home? I guess I truly don't know what that is.
Adding Flooring/Drywall/Insulation in Portable Storage Building Ashley DIY Building & Construction 0 07-12-2012 11:06 PM
Trex and Building Codes Jamie O'Leary Remodeling 6 04-19-2012 09:49 PM
Container homes, what foundations does it need?? shabba1985 Building & Construction 27 03-08-2012 01:48 AM
building a main and sub panels for 2 remote buildings n175h Electrical 30 12-20-2011 03:09 PM
Does your job require a permit? housedocs General DIY Discussions 203 12-01-2010 08:28 AM
