Build A Floor Over A Uneven Concrete Slab - Flooring - DIY Chatroom Home Improvement Forum
Old 01-08-2017, 06:00 AM   #1
Rewards Points: 6
Build A floor over a uneven Concrete slab
New member who just purchased his first house, a 100 year old 1500 sq ft country house. Now for the projects:
First big one, of course many, many small ones as well, but here it is:
One of the big bonuses of the house was that it has a 11x37 bonus room that was once a sun room. I want to convert it to the master and bath with a small laundry room. The issue is that the slab is in great condition but not level. It appears that that there is about a 1/2-3/4" drop in areas of the floor and I will need to get this level. My thoughts are:
1) I know that there are self leveling concrete options but that would be pricing with the size of the room. so I have been thinking about using a laser level to find the high and low spots. Frame in the outline of the new floor and then cut each joist to the outline of the uneven floor. I am thinking about using 2x8' which would level it up with the floor of the main house.
2) I will need to put a vapor barrier in and not sure of the standard plastic is the best option or is there something better?
3) Options for insulation?
Is this approach above even the best option for this type of project?
I am good with my hands and have tackled tons of home projects but this is the first of this type so looking for advise.
Steve
sgilbert14 is offline   Reply With Quote
Old 01-08-2017, 07:54 AM   #2
Rewards Points: 240
Re: Build A floor over a uneven Concrete slab
your location = very important
Fix'n it is offline   Reply With Quote
Old 01-08-2017, 07:59 AM   #3
Rewards Points: 6
Binghamton NY area
Old 01-08-2017, 08:16 AM   #4
Rewards Points: 240
ok. idk what,if any, vapor barrier and/or insulaation you should use.
but the joists. build the entire joist structure. then use a self leveling laser and go around and shim up the low spots.
Old 01-08-2017, 08:39 AM   #5
Rewards Points: 6
Sounds like a plan. Much easier than doing profiles joist to the concrete
Old 01-08-2017, 09:08 AM   #6
Rewards Points: 240
to say the least ....
Trying to install pavers or tile over concrete slab in questionable condition sallen Landscaping & Lawn Care 1 07-10-2016 08:43 AM
uneven concrete slab build1234 Flooring 1 12-16-2012 05:44 AM
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 02:46 PM
Supporting Concrete Slab from Underneath? Yippydadada Building & Construction 5 10-18-2011 04:24 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
