Bubbles In Vinyl Flooring In Kitchen - Flooring - DIY Chatroom Home Improvement Forum
Old 03-22-2005, 02:19 PM   #1
Bubbles in vinyl flooring in kitchen
We have recently had vinyl flooring put in our kitchen and the plywood that has been glued onto the concrete sub-strate is 'bubbling up' in places. What course of action needs to be taken to stop it from springing again when the floor gets relaid.
Thank you for your help
imported_Karen is offline   Reply With Quote
Old 03-22-2005, 08:46 PM   #2
Karen
There are various reasons this could of happened. moisture could of affected the glue. the concrete possibly could of heaved or moved. or the most probable, the plywood was put down without any room for expansion. I am not sure were the best place for expansion gaps would be (probably outside edges of room). If their is no place for the wood to expand it will buckle under temperature and humidity changes.
Mgmopar
MgMopar is offline   Reply With Quote
Old 03-17-2011, 11:15 PM   #3
Aged Sleeper
Bken's Avatar
you could have bubbles caused by a bad installation. The installer (OR) contractor often uses the wrong adhesives.. that could be tested and you can find out
Bken is offline   Reply With Quote
Old 03-17-2011, 11:24 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 14
Gluing plywood to a concrete subfloor is a bad idea in the first place. The vinyl should be installed directly on the concrete.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
oh'mike (03-18-2011)
Old 03-18-2011, 06:56 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why is the plywood there?
There is no need for it and you shouldn't expect it to stay glued to a concrete substrate.
Remove everything and start over. This time...install the vinyl directly to the concrete.
XXX
