Bubbles In Hardwood Finish - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 10:54 PM   #16
DIY staff
Rewards Points: 7,174
Good luck----LL has a lot of complaints---I'm just guessing--but yhe will likely find an excuse not to fix this----
See if a local floor installer or supplier can send someone out to asses the failure---this may cost you a bit----so be prepared for that---that is the best way to get an honest answer from a pro,
Do be patient---we have several full time hardwood installers here---perhaps one will see this and recognize the cause of your finish failure----
Old 03-12-2013, 10:55 PM   #17
Rewards Points: 12,840
Lumber Liqiudators has a horrid reputation.
To bad, 0 excuse for it.
So good luck with tryong to go through them.
The stupid comment on it may be termite damage without seeing it in person should be your first clue as to what's going to follow.
Old 03-13-2013, 09:08 AM   #18
Rewards Points: 150
Yes, and they've earned it.
Before I decided on a hardwood flooring source, I did a lot of research on boards such as this. It was a ubiquitous opinion that people should be wary of Lumber Liquidators, mainly because they do not stand behind their products.
Not that there weren't stories of great products and service from them. I sincerely hope that your story ends well. But I had read enough to get me looking elsewhere, and I am happy that I did.
When you said "bubbles" I thought, well, bubbles. That looks like a wholesale failure of the finish. Since it is spread out, but mostly (or solely) in one room it could be just one bad box.
zakany is offline   Reply With Quote
Sanding methods for uneven hardwood floors inquisitiveblue Flooring 3 08-05-2011 11:49 AM
I damaged the finish on my hardwood floor! Lasa Flooring 12 08-03-2011 07:45 PM
best hardwood floor finish for natural color acerunner Flooring 3 07-08-2011 10:19 PM
Repair bubbles in wood floor finish renter Flooring 7 05-28-2011 03:24 PM
hardwood floor transition from old to new cooter Flooring 4 05-25-2009 11:20 AM
