-   -   Bruce Lock & Fold engineered hardwood? (http://www.diychatroom.com/f5/bruce-lock-fold-engineered-hardwood-7282/)
zel 03-21-2007 07:48 PM
:thumbsup: Has anyone used this yet? We are considering it for the master bedroom. It seems to be easy to install like laminate, but has the high quality of real wood. I'm just looking for opinions and suggestions on this. Lowes is having a 20% off sale on special order flooring. Thanks!
zel 03-22-2007 08:36 AM
Anyone? Bueller?...Bueller?...
sedwick 03-22-2007 11:35 AM
Hi Zel, i've been suckered into putting this down in my mother-in-laws living room this saturday, i would like some advice also.
Floorwizard 03-22-2007 12:33 PM
Probably a thin engineered.
nothin wrong with that. unless you want higher quality, or a different type of species.
zel 03-22-2007 03:53 PM
thanks for the replies! It is 3/8" thick. When looking at the end, it looks like plywood. We went to Lowes to get some samples last night. I guess my question was a little vague. I'm wondering about the ease of installation? Also, if the planks are laid parallell to the floor joists, will I see "ridges" when looking across the floor? I have 3/4" ply over 2x4 joists, with the "4" side being the nailing surface for the subfloor. The joist spacing is 2' and when gutting the bathroom, I noticed the subfloor sags a little between the joists.
Floorwizard 03-22-2007 11:52 PM
3/8 is thin but still a wood that will be o.k.
gluing to subfloor is fine, it is an engineered (ply) so that is acceptable, but the sagging needs to be corrected before install.
zel 03-23-2007 12:03 AM
Thanks for the reply. The whole house is like that. I dont see any way of correcting the sagging, short of rebuilding the house.
rbodenschatz 03-29-2007 01:25 PM
I thought about using it in my basement. Bought a case and tried to lay it out on my floor as a test. Pure crap. It will not lay flat. Cups. I suspect that if I had connected the whole case, I would've ended up with a tube. It's junk.
ron schenker 03-29-2007 04:24 PM
Let me get this straight now...Are you saying don't use it?:laughing:
Floorwizard 03-30-2007 10:22 PM
it cups right off the start?
Was it acclimated?
Do you have a humidifier?
smgray 04-08-2007 12:32 AM
Bruce Locking
I just used this flooring today and I did about 1/3 of my office/living room. I love it. You have to be sure to press the locking edge under the receiving edge firmly before you lay it down and some boards won't lay down as well as others but so far 90% of the boards I have laid have went in with ease and the other 10% worked elsewhere. The only point where there is any issue is the space where the two rooms meet. Laying the floor was so easy that I just picked up what I had laid in that area and did it again. As for the "cupping" comment: of course there will a little of that if you lay a few pieces without a moulding to hold the edges down. Even when I was in the store putting samples together they weren't flat but the weight of the floor and the moulding keep the floor in line. I used a spare box or two to weight the floor down while I was working. I'm actually looking forward to finishing up tommorrow.
PS - I bought at Lowe's during the 20% off sale too.
zel 04-08-2007 12:42 AM
Great info! Thanks!
smgray 04-08-2007 01:02 AM
http://photos-422.ak.facebook.com/ph...25422_8260.jpg
Genghis1971 04-09-2007 10:49 PM
I stumbled across this board while looking for information about the Lock & Fold flooring. I'm looking at trying it late this year but it will be a big project at ~750 sqft. In the meantime I'm gonna be scouring the net looking for comments and tips.
smgray- thanks for the pic and the positive comments. I'd welcome any helpful hints you come up with based on your experiences. That goes for anyone else out there (Sedwick??)
zel- I'd love to hear your experience if you try it but I agree with Florcraft, everything I have read has stressed the need for the subfloor to be completely level.
I am on a slab so one of my questions concerns verifying the concrete moisture content. They recommend using a "Tramex concrete moisture encounter meter". Since I've never had to have my concrete moisture measured, is that something I can rent from a typical hardware store?
If this thread is still alive when I finish mine I'll be sure to post my comments.
smgray 04-10-2007 01:54 PM
The subfloor needs to be very flat in a newer building but the slight dips in my concrete subfloor has given the floor a sound that is authentic for a 90 year old condo. Just be sure not to leave and tiny bits of plaster, concrete, tile or anything hard under the floor. I have only cut about six pieces in laying 200+ sq. ft. The less you cut the better as any peice you cut will have limited utility once you cut off the locking edge. It takes a long time to lay it without cutting but they give you enough variations in length to fit almost any space.
http://photos-105.ak.facebook.com/ip...33105_1489.jpg
