Is Bruce Everbond Any Good - Flooring - DIY Chatroom Home Improvement Forum
Old 12-13-2009, 06:53 PM   #1
Is Bruce Everbond any good
Is Bruce Everbond any good? I'm installing Bruce engineered flooring on first story concrete slab in Tennessee. I purchased wood and glue from lowes. $75 for the glue. I did some research and a Urethane adhesive Armstrong ProConect is mentioned in the instructions. I also see Bosticks best glue is really good to. Should I take this Everbond back to Lowes and get something else. My wood floors have to acclamate for three days before I start my project.
glgreg is offline   Reply With Quote
Old 12-13-2009, 08:38 PM   #2
Glue
Ok folks, I did some research here and looks like I'll return the Everbond and go get some urethane adhesive. This stuff looks ok.....
http://www.lumberliquidators.com/cat...c_id=CSE_NT_07
Does everyone agree?
Old 12-16-2009, 05:04 PM   #3
Still Learning
I've never had much confidence in Bruce adhesives after being burned by one (Tribond) they dropped about ten years ago. It was a total failure and they would never admit to it. Bostiks is a great alternative, providing you follow all the specs.
HardwoodGuy is offline   Reply With Quote
Old 12-16-2009, 06:04 PM   #4
msv
Hardwood pro
msv's Avatar
as the previous post says, as long as you follow the instructions, Bostik is the best thing out there... Nothing i've used or tried compares to it... Water doesn't affect it, neither does moisture, temperature, etc.... it's pricey, but it's worth every cent. Now, there's a new one from Bostik, called Bostik EFA(engineered flooring adhesive) that's around $100 per bucket(Bostik Best is over $160). I've never used it, but you can do some research on it..
good luck.
50% down, 50% after all your complaints....
Hardwood Floor Refinishing Roswell
msv is offline   Reply With Quote
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 04:49 PM
Recommendations for a good corded and/or cordless drill jimmyfloyd Tools 15 11-30-2008 11:20 AM
How can I tell if my taping is good enough? yummy mummy Building & Construction 4 10-01-2008 09:16 AM
Good equipment to use for carpet cleaning? Beth777 General DIY Discussions 5 08-29-2008 08:16 PM
