Bruce Enginnered Click And Lock Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 04-23-2012, 07:10 PM   #1
J&j
Bruce enginnered click and lock flooring
Do I need a tapping block to install and where do I get one? Is it just a scrap of wood or somthing made with the correct groove?
J&j is offline   Reply With Quote
Old 04-23-2012, 07:21 PM   #2
Rewards Points: 13,450
Your going to need several tools, a Z bar to lock in the short joints, A tapping block, compound mitre saw, an under cut saw for the door jambs and casing, and a mallet. (I use a dead blow rubber hammer not a black rubber mallet because it leaves marks.)
Do not waste money on the cheap Pergo brand tools buy Roberts brand instead, I think Lowes has them. There much more sturdy.
DO not remove the baseboards, you only need to remove the 1/4 rd.
Instead of cheap plastic spaces I use strips of plywood and just tack them up with finish nails. The little plastic pieces keep falling over.
J&j (04-25-2012)
Old 04-25-2012, 03:40 PM   #3
J&j
Thanks ... I'm going to tackle the job this weekend. I have found a plastic tapping block at Lowes and I have the other tools you mentioned. I'll update on the progress.
Jim
underlayment for click and lock hardwood flooring fawnlion Flooring 2 12-06-2010 03:03 PM
click lock wood flooring and tile guessingo Flooring 3 09-15-2010 10:56 PM
click lock flooring router bit davimarti Carpentry 3 09-29-2009 07:58 PM
Cabin grade vs 1st quality Bruce Lock N Fold Treasures Flooring 4 09-12-2009 10:03 PM
Click lock floors under baseboards ? bcarwell Flooring 4 03-30-2008 11:03 PM
