Old 04-26-2010, 01:29 PM   #1
bridging
what would be the most effective ( if any ) way to install bridging to 2x6 floor joist spaced 16'' apart that already has the subfloor installed.
My house is on piers and ill have access underneath.
thanks
rustic is offline   Reply With Quote
Old 04-26-2010, 02:06 PM   #2
the Musigician
DangerMouse's Avatar
bridging
I'd use 14-1/2" (approximate length) 2X6s in between at intervals determined by the size of the floor.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 04-26-2010, 04:05 PM   #3
bridging
ok, thanks
Bridging or blocking floor joists jlmran Building & Construction 1 03-19-2010 10:03 PM
Floor Joist Bridging mike boufford Building & Construction 5 01-27-2010 04:42 PM
what to get for bridging 2x6 24" oc? Tonglebeak Building & Construction 17 01-26-2010 05:53 PM
what span needs bridging ugabulldog Building & Construction 7 10-20-2008 10:00 PM
Bridging Ground wires. Duppy Electrical 13 01-17-2007 07:31 PM
