Old 08-18-2007, 04:24 PM   #1
Default Brick and wood flooring
I have seen some pictures of brick flooring with wood trim. The wood forms rectangular fields that are filled in with brick. It appears that the wood used in the photos I've seen is 6" wide oak.
Doing the brick portion doesn't concern me; I'll just use "thin bricks" and adhere with thinset. But I don't know how to incorporate the wood. I will be installing it on concrete slab. How do I attach the wood to the slab? I was also cautioned to allow room for expansion of the wood, but I assumed that I would grout between the bricks. How do I leave for the expansion if I'm grouting between the bricks and wood?
I'm assuming that I will leave the wood unprotected while grouting and then sand it down and apply a sealer to both the wood and bricks upon completion. Or is that an incorrect assumption?
Any thoughts or suggestions as to how to proceed? Thanks.
jhughesfam is offline   Reply With Quote
Old 08-18-2007, 05:29 PM   #2
Tileman-Manufacturers rep
I've seen two such floors, and I was there to repair both. I don't think much of this look or type of installation. You've got one item that could last 50 years, and the other will need refinishing in 8-10 years. Then what?
Your choice for the wood is engineered pre-finished hardwood, glued to the concrete. As you said you'd thinset the bricks, and yes you'll need to leave a gap between the two and use a caulk at the wood/brick joint.
Instead of using wood, why not use porcelain tile planks that look like wood and even a porcelain that looks like brick or stone instead of the hard to maintain thin bricks?
More On This Topic
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com and in this segment, I am going to show you how to apply a grout and talk about grout a little bit. There are three separate kinds of grout. There is a sandy grout, non-sandy grout... Read More »
Hi. I am Chitrotpola speaking on behalf of Expert Village and I am at Art Space India. I am now standing in front of a very large kilns. Now what is a furnace? This is a very large furnace. It is made from fire bricks, very special kind of bricks. Which... Read More »
Hi! My name is Vincent Sansone and I am the Head of the Ceramics Department here at Crealde School of Art in Winter Park. Today for Expert Village I am going to show you how to make a slab pot over a hump mold. So, first you take a piece of clay and cut... Read More »
Hi, I’m Faith and I’m here at Flat Fork Studio and I’m here to show you some basic tools that you want to have on hand when preparing to do your mosaic tile project. First we have a caulk gun, Liquid Nails adhesive. This is one type of... Read More »
How to Apply Mosaic Grout
How to Apply Mosaic Grout by Expert Village
Okay, now this is a good consistency for the grout. You can see that it's pretty thick and now we're ready. Now you want to wear rubber gloves when you do this work because the grout can be a little bit harsh on your hands. And you want to have a sponge... Read More »
Attaching Limestone Sills to Wood Framing BigJimmy Carpentry 8 11-14-2008 11:11 PM
wood frame addition on brick home sandyman720 Building & Construction 0 03-05-2007 10:08 PM
Cutting brick to install windows (lentals?) buckwillis Building & Construction 6 08-21-2006 10:13 PM
Steel Beam or Wood Reinforcement for 2nd floor addition? coralhead1 Building & Construction 2 06-06-2006 03:22 PM
PORCH - from BRICK to WOOD Kukurigu Building & Construction 1 11-12-2005 11:33 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
