Brand New Home And Sharp Tack Strips - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-30-2012, 02:23 PM   #16
Rewards Points: 370
Don't be surprised if the reply is " that's normal and the way we do all of them ".
Here is hoping it is better than that because that phrase is about worn out and builders need to come up with a new one.
If it were me I'd probably be looking for another house built by a different builder because that short cut may be minor compared to others that may have been taken.
SeniorSitizen is offline   Reply With Quote
Old 11-30-2012, 04:21 PM   #17
Rewards Points: 5,974
If I'm not mistaken don't they make different transitions for different surfaces like carpet to tile, carpet to wood, tile to wood, and so on?
Old 11-30-2012, 04:23 PM   #18
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
Yes they do and some of us, use them.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
ToolSeeker (12-01-2012)
Old 12-02-2012, 09:38 AM   #19
Thank you so much everyone. I brought the CRI 105 installation standards up and the builder finally admitted it--so they're going to have the carpet re-installed with shorter pins on the tack strips.
But I also would like to see what you guys think about this, the inspector noticed that there's honeycombing or air pockets visible on the foundation walls. The builder, as usual said that this is something normal. I don't trust anything they say anymore, do you think this is something normal or should they fix it?Name:  pookie.jpg
danandlova is offline   Reply With Quote
Old 12-02-2012, 10:40 AM   #20
Rewards Points: 12
Attachment 61306
They still need to use transitions in the doorways.
Old 12-02-2012, 10:50 AM   #21
mike owes me $53 dollars
Tech Dawg's Avatar
Sounds like a typical New Construction deal... Builders will use the lowest grade carpet which is thin and the tack strip spikes pop through.
This happened at my house when I bought and it was my fault for overlooking the carpet grade. We had so many selections to make that the Ole Lady was more concerned with colors but now I'm concerned that I have a house full of el-cheapo carpet to replace
Todd
www.aloneeagle.com
Tech Dawg is offline   Reply With Quote
Old 12-03-2012, 07:08 AM   #22
I'm not a concrete guy but sure doesn't look normal to me, and apparently didn't look normal to the inspector that looks at a lot of homes.
Old 12-04-2012, 10:18 AM   #23
Good for you on getting an inspector "even though the house is new". I hear so many horror stories.
MissKat is offline   Reply With Quote
Old 12-04-2012, 12:40 PM   #24
Rewards Points: 150
I'm not a concrete guy, either, but voids like that are caused by not vibrating the concrete sufficiently during a pour, aren't they? I don't think there's a fix for that, since the air pockets you see are just the ones you see. No telling if the walls aren't chock full of air pockets.
I was just wondering what you're going to replace your carpet with in ten years.
zakany is offline   Reply With Quote
Tags
carpet , hardwood , transition
