Bouncy Mortar Bed - Flooring - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-09-2008, 12:24 PM   #31
Zero Punch,
I appreciate the suggestion. I am actually going to do something similar. I am going to sister 2x8s alongside the current floor joists and level off that way in order to avoid another mortar bed.That way all the joists are level and I can just lay the 3/4 plywood and that would be level too. I will then spread some thinset attach 1/4 backerboard and then tile on top of that.
After the experience of laying one bed down and then having to rip it out, I am now trying to see if I can just totally avoid needing mortar at all.
Thanks for the reply
padola07 is offline   Reply With Quote
Basement Wall Mortar rory535 Building & Construction 16 08-06-2009 09:39 AM
Can I dye existing brick mortar? Foo by Tore General DIY Discussions 2 10-30-2008 07:03 PM
Is it bad to use mortar to level a floor? CB2007 Flooring 4 10-01-2008 08:38 AM
Mortar removal from salvaged brick. Rem8 Building & Construction 8 07-20-2008 07:05 AM
can I reuse mortar bed ? mf915 Flooring 1 07-04-2006 07:14 PM
