Bouncy Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 06-04-2012, 09:27 PM   #1
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
We have a problem in a house our preacher lives in. Lowe's installed some laminate flooring and for some reason there is a hump in on spot that is springy when you step on it. We took the flooring up and we didn't find anything under the flooring or any reason it would be humped and springy in just one small spot.
My question is this, is there a type of glue I could glue that one spot down? There is plenty of clearance for the floor to move so that isn't the problem. I was thinking maybe use a butyl caulk to glue that spot down as the butyl caulk doesn't completely harden and would move if the flooring expanded or contracted. Will this work or what should I use?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 06-04-2012, 09:35 PM   #2
Rewards Points: 13,270
Look over the tongues and droves for any damage.
One trick I use when installing laminite is to never just try and force it down in one motion. I sort of work it up and down going lower each time. It works the T & G into the grove.
Once I have tapped the butt joints together I tap over the whole surface with a dead blow hammer gently. I've seen the tiny gaps close up from doing this one thing, and it stops the floor from trying to pop back up.
Old 06-04-2012, 10:13 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
Thanks Joe, I will give that a try.
Jim
Old 06-05-2012, 08:58 AM   #4
Rewards Points: 220
sure the planks were not bowed ? i had that problem with engineered i did in my old place. the directions said it was ok to use slightly bowed boards = don't believe that.
Fix'n it is offline   Reply With Quote
Old 06-05-2012, 08:25 PM   #5
Pro
JetSwet's Avatar
Rewards Points: 502
I wouldn't suggest any glue for laminate, if the planks have peeked or popped up then it should be replaced so it doesn't happen again because if the T&G is damaged its going to expand in that area before it uses the perimeter to expand.
Also double check all walls for expansion gaps.
JetSwet is offline   Reply With Quote
Old 06-05-2012, 09:04 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
I took that area up today and there was a hump in the underlayment, sanded that area down so it is dead flat now. I will reinstall new flooring tomorrow and see if that takes care of it. Thanks a bunch for all your help, I do appreciate it.
Jim
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
How do you install laminate flooring under door casings? Player Flooring 34 07-16-2010 05:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
