-   -   Bouncy floor (http://www.diychatroom.com/f5/bouncy-floor-148159/)
Nonnio 06-25-2012 04:02 AM
Bouncy floor
My house is over a hundred years old we are coming to the end of a very big revolution. However the upstairs floor bouncy when you walk on them. It is in two areas near an internal wall that is each side of the stair case. What should I do about it?
joecaption 06-25-2012 06:58 AM
Is the ceiling in the down stairs room open or the subfloor in the room above out?
If not then there's not much you can do.
You have to be able to get to it to find out what's wrong and fix it.
The things I have found when working on old houses is someone over the years has removed a supporting wall without taking the time to install some sort of header to replace it.
Undersized floor joist with to long a span.
Insect damage.
Nonnio 06-25-2012 08:27 AM
The floor runs way from the wall the floor joists run in the opposite direction. All the sealings are new having been replaced 6 months ago as was the wall.
Should I now contact a builder?
oh'mike 06-25-2012 09:38 AM
Yes--call the builder--ask if he has progress pictures of the structure before the drywall went up--
Canarywood1 06-25-2012 11:39 AM
I think you need to reread this post!
Evstarr 06-25-2012 11:50 AM
Lol the builder might have a library of oil paintings!
oh'mike 06-25-2012 12:10 PM
Sorry---the posters spelling 'revolution' made no sense I thought perhaps he meant remodel--
As new drywall on the ceiling was mentioned also--I figured the the 'builder' he was going to call was the same as the one that just finished up the 'revolution' and added the new drywall---
However,I'm wrong a lot of the time--so we will see.
joecaption 06-25-2012 12:13 PM
That would be one long distance call to make.
CopperClad 06-25-2012 12:19 PM
So I don't get it... Did you do the revolution? or did you hire someone to do the revolution? Was the floor at all bouncy before the revolution? Sounds peculiar....
Canarywood1 06-25-2012 01:44 PM
This is the part i'm talking about Mike.
"My house is over a hundred years old." i doubt that builder is still around.
