Bouncy Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 09-18-2011, 09:14 PM   #1
bouncy floor
I purchased a 13 year old one level home with an unfinished basement. The floor joists are 2 X 10 and span a distant of about 15 1/2 feet. There is no bridging between the joists. The joists rest on the foundation at one end and on a steel I beam at the other end. The floor is level and the joist are level (they are 95 1/2 inches off the floor at each end and the same in the middle).
I have read that the best method to solve the springy floor problem is to sister another 2 X 10 to the existing joist and glue and nail or screw them together. Also, the sister does not need to run the length of the existing joist but can be either 8 or 10 foot and fastened along the middle length of the existing joist. Also, I should add bridging between the joists.
I would appreciate your thoughts on this
gatorcew is offline   Reply With Quote
Old 09-18-2011, 09:29 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If that is what you have read then it must be true. Go for it and see if it helps.
Strengthening a bouncy floor jdelisle Building & Construction 13 10-30-2012 05:47 PM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 05:42 AM
Tiling over bouncy floor Millertyme Tiling, ceramics, marble 6 09-13-2010 10:15 PM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 06:32 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
