Boiler Alcove Simplest Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 04-11-2011, 04:34 PM   #1
Rewards Points: 1,062
boiler alcove simplest flooring
i was wondering what the SIMPLEST/CHEAPEST boiler/water heater alcove flooring would be. both the hydronic radiator boiler and the water heater are gas. i doubt i could just leave exposed subfloor, i.e. it should have some finish tier, e.g. tile but i think tiling is just an overkill. the subfloor also currently has 6 pipes going through it (coming from the basement) and i also want to avoid having to project the same position of holes on hardibecker, which is the kind of tedious work i really hate.
was thinking of putting linoleum but was skeptical if it may melt under gas appliances.
ideas, please !
Setting the reset "Curve" for a modulating boiler (modcon) mknmike HVAC 5 02-10-2011 11:37 AM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Burnham boiler banging/thumping noises quadradeuce HVAC 6 10-02-2010 09:55 PM
Boiler size Bonnie Youngs HVAC 29 07-10-2009 07:58 PM
