Old 11-29-2008, 08:40 AM   #1
Bleach then seal grout?
I have either ceramic or porcelain GLAZED tiles...Have kinda a light gray grout but have has some puppy accidents and it's turned the grout dark gray. Technically I don't care what color the grout is, I just want it uniform. What methods can I do? My 15min google search had everything from hydrogen peroxide to an industrial cleaner. I have approx. 300sq/ft and 12" tiles...
I'm hoping there's a somewhat inexpensive solution that doesn't require extensive scrubing. Does a product or household cleaner exist? Also, after the grout is cleaned, how long do I have to wait to seal it? Any recommendations of a sealer?
Bacardi 151 is offline   Reply With Quote
Old 11-29-2008, 11:23 AM   #2
Doer of Many Things
poppameth's Avatar
Oxyclean works better than you'd expect for this. However, I'd recommend a grout dye from Aquamix. It'll dye the grout whatever color you want it and seal it with an epoxy solution to keep it from staining again.
poppameth is offline   Reply With Quote
seal a polished marble bathroom floor? tarheelblue Flooring 21 01-12-2012 12:58 PM
Sealing grout for outdoor granite sidewalk TVM Tiling, ceramics, marble 17 02-16-2009 08:09 PM
sanding grout C99 Flooring 4 02-18-2008 06:10 PM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 11:59 PM
Do Tile setters seal grout? Yeti Flooring 2 10-24-2007 06:18 PM
