Blacktop Over Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 05-09-2006, 01:22 PM   #1
ssc
blacktop over concrete
is it possible to put blacktop over concrete and have it last. I saw it done one time , in about 2 monthes ,all the blacktop cracked and came apart from the concrete as if it was there 10 yrs. It had to be ripped offf eventually. If possible , how is it done so it sticks
ssc is offline   Reply With Quote
Old 05-31-2006, 04:50 PM   #2
Construction Man
Chuckman's Avatar
its better to go ahead and bust up the concrete so you will know the blacktop will have good surface to set too
Chuckman is offline   Reply With Quote
Old 05-31-2006, 04:51 PM   #3
Construction Man
Chuckman's Avatar
but if you want blacktop on top of the concrete, this might not saying it will but might you could use tack oil its really sticky and u spray it on before you pave over it but the best decision would to bust it all up
Old 06-01-2006, 07:16 PM   #4
Rewards Points: 150
A paver can apply an underlayment that will greatly reduce the extent to which concrete flaws will show through the asphalt. Talk to a local paver.
pipeguy is offline   Reply With Quote
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
