Black Residue - Flooring - DIY Chatroom Home Improvement Forum
Old 08-03-2009, 11:22 AM   #1
Post
Black residue
I have removed the old tiles from my bathroom (from 1973) and there is a very thin black residue on about 90% of the concrete. I'm going to put in ceramic tiles and need to know if I need to somehow remove this residue. It is almost like a stain, or something VERY thin. By the way, the old tiles were under some self-stick ones. While removing the self-stick tiles these other old tiles just lifted without any problem. I sure would appreciate any suggestions or information that could be shared about this.
bamamama is offline   Reply With Quote
Old 08-04-2009, 07:15 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Install your new ceramic tile using "modified thinset tile mortar" suitable for use over "cutback adhesive", no big deal.
Old 08-04-2009, 09:39 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 422
Absolutely no problem, we've done it hundreds of tile. You should cut this black adhesive with a razor cutter, it's called a wallpaper scraper. Do not sand or use any chemical. You'll be OK when you can almost see the concrete. Use a good quality modified thin set that states it's OK over "cut-back" residue, as Bud said.
The scrapper looks like this; http://www.core-industrial.com/manag...28Small%29.jpg
Jaz
Old 08-19-2009, 01:35 PM   #4
Thumbs up
Thank You.
Followed your advice and finished the job Monday.
3 Black, 3 White, I'm clueless about Fan Replacement kendor Electrical 4 04-04-2009 04:36 PM
Black stuff under thinset? Osiris Flooring 1 04-04-2009 04:09 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
refitting black pipe that has black gunky dope settled in amakarevic Plumbing 6 06-16-2008 12:05 PM
Install hardwood over black mastic? SuperDoug Flooring 2 10-28-2007 12:52 PM
