Old 01-13-2013, 10:15 PM   #1
black emulsion adhesive
Hi All
Can ceramic tile be installed over old black emulsion adhesive on concrete??
Thanks in advance for your great advice.
RH913RH is offline   Reply With Quote
Old 01-14-2013, 06:59 AM   #2
Super Moderator
Yes-----Kerabond mixed with Keralastic will work----I believe that some better modified thin set can be used over cutback---call the technical help line for the brand you have available---
If leveling is needed---Jifset mixed with Linewebers liquid latex is approved for that---
DO NOT use any solvents in an attempt to remove the cut back---it will soak into the slab and become a 'bond breaker' and put your installation at risk----Just use a razor scraper and start tiling.
Old 01-14-2013, 07:12 AM   #3
Pro Flooring Installer
rusty baker's Avatar
Use a spray bottle with water and keep it damp while scraping. It probably contains asbestos.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
oh'mike (01-14-2013)
Validating Wiring For New Bathroom Fans jdjd Electrical 3 07-23-2012 03:39 PM
Two black wires and two white wires in a ceiling mshaw11 Electrical 6 07-11-2012 10:57 PM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 50 09-01-2009 09:20 PM
Black Iron Exposed? jamiedolan Plumbing 0 08-14-2009 11:16 AM
Black stuff under thinset? Osiris Flooring 1 04-04-2009 05:09 PM
