-   -   black emulsion adhesive (http://www.diychatroom.com/f5/black-emulsion-adhesive-169058/)
RH913RH 01-13-2013 09:15 PM
Hi All
Can ceramic tile be installed over old black emulsion adhesive on concrete??
Thanks in advance for your great advice.
oh'mike 01-14-2013 05:59 AM
Yes-----Kerabond mixed with Keralastic will work----I believe that some better modified thin set can be used over cutback---call the technical help line for the brand you have available---
If leveling is needed---Jifset mixed with Linewebers liquid latex is approved for that---
DO NOT use any solvents in an attempt to remove the cut back---it will soak into the slab and become a 'bond breaker' and put your installation at risk----Just use a razor scraper and start tiling.
rusty baker 01-14-2013 06:12 AM
Use a spray bottle with water and keep it damp while scraping. It probably contains asbestos.
