Black Cut Back Left - Flooring - DIY Chatroom Home Improvement Forum
Old 05-15-2014, 09:11 AM   #1
Rewards Points: 93
Black Cut Back left
Good Morning
Looking for some advice and input.
Pulled up some old vinyl and I now have black cutback adhesive left. It is on top on 2 1/4" white oak hardwoods.
i am looking for the safest/best way to remove this. I am under the impression that it most likely contains asbestos. I am going to treat it as it does regardless.
Would wetting it down well with soapy water and then removing the actually hardwood boards be the best way to get rid of it?
Ideally we want to refinish the hardwoods but if ripping up and installing new hardwoods is the safest bet, i'll go that road.
bfan781 is offline   Reply With Quote
Old 05-15-2014, 11:09 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
I don't know of any way to save the hardwood. If you use a chemical to take up the cutback, a finish will probably not stick to the hardwood. You can scrape up most of the cutback, but you can't sand the rest of it if it contains asbestos.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 05-15-2014, 11:28 AM   #3
Rewards Points: 93
Yes I agree, that is why I was thinking it maybe easier to just soak it down to contain any dust and rip out the adhesive and hardwood all at once.
Just seeing if anyone else does this and if it is considered a safe approach
Old 05-15-2014, 12:03 PM   #4
Rewards Points: 1,204
Might be worth the price to have the residue analyzed at an asbestos abatement center.
And they can advise you on how to remove it or replace it.
ED
de-nagorg is offline   Reply With Quote
Townhouse Development : Black Streaks on Siding at Attic Level Krell Roofing/Siding 5 01-29-2014 12:40 PM
back of house ideas needed Startingover Landscaping & Lawn Care 2 11-04-2013 06:21 PM
can't get new combo switch outlet to work woodcrazy Electrical 6 01-15-2013 09:52 PM
Putting carpet back xandrew245x Flooring 1 09-19-2012 09:57 AM
Wiring Switched Outlet matt151617 Electrical 15 07-03-2011 02:16 PM
