Old 03-04-2012, 07:37 PM   #1
Best way to wrap Hardi around Toilet Flange
I am currently undergoing a retile in my Master Bath. I am adding Hardi (which was not originally installed). My plan was to just draw out a pattern onto the cement board and split it down the middle so I can slide both halves underneath the toilet flange. Does this sound ok or is there a better way of doing it? Thanks!
veesmack323 is offline   Reply With Quote
Old 03-04-2012, 07:42 PM   #2
Is it cast iron or PVC?
If it's PVC it's simple enough to just cut off the pipe below the floor and slide it out.
Old 03-04-2012, 07:43 PM   #3
Its PVC but I definatley do not want to cut out the flange if I dont have to.
Old 03-04-2012, 07:53 PM   #4
Tileguy
JazMan's Avatar
That's fine. There's really no need to slip the backer under the flange.
And the reason is..........? I think you may have misunderstood.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 03-04-2012, 08:03 PM   #5
Remodeling Contractor
You may have to add an extension to the toilet flange so
you are flush with the finished tile
pgc555 is offline   Reply With Quote
Old 03-04-2012, 08:31 PM   #6
Well I actually measured a portion of the floor that ive already finished with a caliper and it it still lower than the height of the flange.....Well see if it comes out that way anyways
Old 03-04-2012, 08:32 PM   #7
Jaz
Why dont I need to put it under the flange??? I thought it had to be resting over the floor??????
Old 03-04-2012, 08:46 PM   #8
Tileguy
JazMan's Avatar
The ideal height of the flange is when the bottom is at the level of the finished floor. The finished floor doesn't actually have to be under it though. The flange is held in place by 3 blocks (wood) and screwed in to the subfloor and can be independent of the backer and tile. Matter of fact I think it should be.
Very often the heights vary a bit, no problem. Just don't have the flange higher than I stated. A little lower is fine and you can "play" with the wax ring to make it work right.
Jaz
Old 03-04-2012, 08:55 PM   #9
Well there are no blocks under this flange. The old tile was directly under it. So I guess the Backer will replace the tile in terms of support....
Old 03-04-2012, 09:00 PM   #10
Tileguy
JazMan's Avatar
NO. Apparently the floor was set before the plumber installed the flange. The flange should support itself. What are the chances that the new backer and tile will be the right thickness? For one.
If the flange is not screwed down what will happen when you bolt the toilet into it?
Jaz
Old 03-04-2012, 09:15 PM   #11
JetSwet's Avatar
The wast pipe comes before your floor install.
Its PVC just replace it altogether, your installing a new floor and will trouble you to get the hight after the floor is done.
JetSwet is offline   Reply With Quote
Old 03-04-2012, 09:26 PM   #12
Tileguy
JazMan's Avatar
The wast (waste) pipe comes before your floor install.
Usually the plumber installs the flange when doing the rough plumbing. Sometimes they wait till after the floor is in if there's any question of what the finished height will be. Happens all the time. It doesn't matter as long as the height is right and the flange is fastened to the floor.
Speaking of heights. What did you remove?
Jaz
Old 03-04-2012, 09:30 PM   #13
Missouri Bound's Avatar
Just cut it to fit around the flange. There are thicker wax rings with rubber gaskets that will more than make up the difference. If the existing flange is secure, don't mess with it. Now if you have acces to the pipe from beneath you certainly can cut it and install the pipe anyway you wish.
Do you want it your way or the right way?
Old 03-04-2012, 10:49 PM   #14
JetSwet's Avatar
Jaz
As a DIYer
Yes the Wast"e" pipe is one of the 1st things to prep and to make shore you won't run into problems after words.
The flange is the last thing you install after tile install.
Old 03-05-2012, 05:15 AM   #15
Jaz
I was planning on unscrewing the flange thats screwed into the subfloor, sliding the backer underneath, then screwing it back down through both the backer and subfloor. The new tile will be around the flange, not under it
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
toilet flange question donkeyk Plumbing 15 02-01-2012 07:46 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 08:41 PM
Toilet flange questions AngeloUCF Plumbing 16 03-09-2011 09:39 PM
