Best Way To Level Sections Of A Concrete Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-09-2012, 12:59 AM   #1
Rewards Points: 264
Best way to level sections of a concrete floor?
What is the best way to level a section of a concrete floor?
I'm thinking of just getting a few bags of concrete and laying it, then maybe going over it with self-leveling compound.
Will that work? I guess I'm just not certain which product I should use, or if it even really matters. Crack-resistant concrete is $5 for 80 pounds, vs $11 for 25 pounds of leveling compound.
Any idea what I should use?
tibberous is offline   Reply With Quote
Old 02-09-2012, 06:08 AM   #2
DIY staff
Rewards Points: 7,174
What are you going to do with the slab after leveling? SLCs are to soft for a finished floor and must be covered with tile/carpet/sheet goods.
Will the slab be exposed to freezing?
Old 02-09-2012, 06:59 AM   #3
Rewards Points: 264
Going to lay down epoxy.
No freezing, it's in a basement.
What about this:
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
How to repair a concrete floor we just had repaired! timbo59 Flooring 11 01-04-2012 06:15 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
Basement concrete floor repair estimate ControlTech Building & Construction 1 04-10-2010 07:28 AM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 04:04 PM
