Best Way To Get To Subfloor? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-02-2012, 11:15 PM   #1
Best way to get to subfloor?
Hello, I am working on remodeling my bathroom. I am going to extend a wall into the adjoining bedroom. The current bathroom floor is a wood floor with peel-n-stick tiles in the bathroom. While I know that will be a pain to remove, I am more concerned about getting the wood floor up. The wood floor is one continuous floor that starts in the hall and continues into the bathroom. I plan on putting wonder board down and obviously need to get to the subfloor. I can see using a circular saw for some of it, but don't see that working in the tighter spaces, and next to the tub ( I may get lucky and they didn't put the wood flooring under the tub). What's the best way to address this?
lindajt9 is offline   Reply With Quote
Old 06-11-2012, 07:45 PM   #2
Rewards Points: 744
Rent or buy a toe-kick saw. Harbor Freight sells a cheap one that should last the job.
Seattle2k is offline   Reply With Quote
Old 06-11-2012, 07:50 PM   #3
Rewards Points: 13,260
You need saw like this, and an ossilating saw to get into the corners.
Old 06-12-2012, 06:32 AM   #4
Rewards Points: 83
A reciprocating saw can work too, you just have to be extremely careful about the depth of the cut. If you do go the toe kick saw route, hold on tight to that thing. I had a coworker eat the entire sleeve on his long sleeve shirt once, and some how avoided drawing blood, much less cutting his arm off.
rubberhead is offline   Reply With Quote
How should I reinforce this subfloor? NewHomeDIYGuy Tiling, ceramics, marble 35 12-05-2011 11:01 AM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Replacing Subfloor whatispunk Flooring 1 09-01-2009 10:50 PM
Subfloor Help, Please! OmahaGirl Flooring 1 01-26-2009 09:06 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
