Old 12-12-2008, 01:09 PM   #1
Enormous Member
skipjack's Avatar
Default Best way to fix poorly finished hardwood floors...
I'm still rehabbing my cookie-cutter 50's ranch house. Anyway, this past week, I finally decided to take a day off work and sand the tattered oak floors throughout the place.
I swung by Home Depot and rented a "U-Sand" floor sander. It's essentially four 6" random orbital sanders attached to a heavy vacuum. Pretty cool, actually.. and really easy to use.
Anyway... and you floor guys might cringe at this, I hadn't really planned to give the floors a whole lot of detailed attention. Just an overall sanding and some poly and be done with it, I thought. Anything I did would be an improvement on what was there and any imperfections I would just write off as "character".
However, once I got started with the sander and I could really see the potential coming out in the floors, I began to take a little more pride in my work.
That is, until I hit one of the bedrooms. Here a previous owner had refinished the floors (I'm thinking in the 80's) with what looks to be a handheld belt sander and some rather rough-grit sandpaper. To get to the point, the U-Sand had a hard time getting through the finish here and, where it did manage to get through, had a hard time smoothing out the "dents" left behind by the belt sander.
Here's a photo of what I'm talking about:
The sanding wound up really highlighting the groove marks in the floor.
So, I ran back to home depot and grabbed the roughest paper I could find for the U-Sand. (24 grit) and planned to just hunker down on these marks until they were gone. But, even with the heavier grit, it was slow going and I wound up having to get the rental back in time.
So, right now I've got two bedrooms that look like the picture above. My plan is to use a chemical stripper to remove whatever poly is left and rent the sander again and just go at it until it's smooth. I'm hoping by stripping, the sander will be able to get a little more "bite" and the smoothing process will go a little quicker.
Anyone have any thoughts on this or see an easier way?
skipjack is offline   Reply With Quote
Old 12-12-2008, 01:17 PM   #2
011000100110111101101111
DangerMouse's Avatar
heya skip.... that looks to me not to be handbelt sander, but rented large floor sander marks left behind by last sander. too wide to be handbelt. with gouges that bad, either you keep sanding or put in a new floor....... i like cork myself. nice and warm on the feet in this weather.
DM
Magical, Musical, Mysterious FUN!
http://www.youtube.com/user/MickeySoume
Now Featuring: Mickey's Multi-Talented Mutts!
Old 12-12-2008, 03:20 PM   #3
Remoldeler
Seen it before. Ho used a hand belt sander. Keep sanding it will come out.
voiles is offline   Reply With Quote
More On This Topic
The Purpose of Sanding
The Purpose of Sanding by Expert Village
Hi, my name is Kevin and on behalf of Expert Village, I'm going to be talking to you today on the use of sanding machines. When you're using sanding machines, primarily you're doing just that. You're sanding, you're achieving a smooth surface that is... Read More »
Hi, my name is Kevin and on behalf of Expert Village I'm going to talk to you about using a random orbital sander on plywood. In your typical plywood situation you've got a thin sheet of veneer over may layers of solid wood that are crossed oriented so... Read More »
How to Use a Belt Sander
How to Use a Belt Sander by Expert Village
Hi, my name is Kevin, and on behalf of Expert Village, I'm going to show you how to use a belt sander on solid wood. So, we're going to use a belt sander on this piece of Oak here, and, with this set up, what we're going to do is we're going to keep this... Read More »
How to Sand End Grain
How to Sand End Grain by Expert Village
Hi, my name is Kevin and on behalf of Expert Village, I'm going to talk about sanding end grain. On this piece of walnut, we've talked a lot about the different sanding; going with the grain, which is always what you want to do. The few exceptions we've... Read More »
Hi, my name's Kevin, and on behalf of Expert Village, I'm going to talk to you a little bit about speed adjustment with a belt sander. On a lot of belt sanders you'll have a speed adjustment that you can adjust the speed to go higher or lower depending... Read More »
New Hardwood Floors = Strange Natural Gas Odor Vlade Divac Flooring 14 10-13-2009 08:11 AM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 01:56 PM
How to get paint off finished hardwood floors? BradG Painting 4 06-14-2008 09:14 PM
Easy maintanence and child friendly Hardwood floors? gante Flooring 2 03-11-2008 10:04 AM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 09:06 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
