Best Way To Attach Cement Board? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-05-2012, 09:19 AM   #16
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Originally Posted by 12penny View Post
Sorry, a little thick today. Dont get this part.
Read post #7.
titanoman is offline   Reply With Quote
Old 01-05-2012, 12:53 PM   #17
DIY staff
Rewards Points: 7,174
It takes so little extra work to do things the best way----Dimensional wood moves to much to put a cement product directly on top ----
Plywood is really quite stable---(3/8" or thicker)
I can give a long warranty over ply and cement backer---but I could not over planks--Mike---
Old 01-05-2012, 01:10 PM   #18
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Thanks for the replies guys. The old planking is even and the joist span is 16" on center or less. The new plywood patches are T&G subfloor approved plywood.
How about putting a thin coat of thin set down on the existing floor, laying my cement board down and screwing it down and then tile?
I'm trying not to raise my floor too much from the rest other rooms.
Also it's a small, chopped-up bathroom with the largest walking area at 36" wide.
Thanks again!
More stupid arguing!!!
Buckman,
Here's the truth of the matter:
Screwing through a cementuous-fill of any kind isn't recommended. Think about it.
You do it however you see fit.
Here's more truth:
Installing cement board directly over dimensional slat-wood is never recommended by the tile installation industry. Dimensional solid wood will move with seasonal changes (expand and contract) and changes in atmospheric (RH) conditions. That's just the way all wood is.
The movement can disrupt the cement board on top of it and quickly wreck a rigid ceramic tile installation. The recommendation of the installation neighborhood is to first install a minimum of 3/8" thick underlayment-grade plywood before installing cement board. This information comes from fifty years of industry testing and studies and experience with the issue.
Again Buckman, You decide what information from an Internet Forum you want to go with and what information you want to gamble with. It's your call - as always.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
12penny (01-05-2012)
Old 01-05-2012, 01:12 PM   #19
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Warning:
The topics covered on this site include activities in which there exists the potential for serious injury or death. (And failure of your project.)DIY Chatroom.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any home improvement task!
XXX
Old 01-05-2012, 01:19 PM   #20
Disabled wood vet
titanoman's Avatar
He probably ran a few extra screws into the existing floor, slapped down some underlayment, tiled it by now, enjoying the fruits of his labor.
And it will look good 5 years from now as well.
Sent from a Samsung Galaxy S2
Old 01-05-2012, 01:38 PM   #21
An Added Complication...
I'm following this thread because I also will be laying tile onto an existing 1929 plank floor with plywood patches. It is also in good shape and very level, on 16" on center floor joists. My added complication is that we are installing a Nuheat Electric radiant heat pad under the tile and our tiles are large format (12x24) so I'm concerned about cracking.
I was considering using 1/4" cement board over the existing subfloor, then thin-setting in the Nuheat pad and thinsetting the tile over that, as per the manufacturer's instructions. After reading this thread, however, I'm inclined to use the suggested 3/8" plywood instead of the cement board. I hesitate to go much thicker because I don't want to raise the floor too high.
I'm also wondering if an isolation membrane between the Nuheat and tile is advisable due to the size of the tiles?
Thanks!
Testarossa214 is offline   Reply With Quote
Old 01-05-2012, 01:43 PM   #22
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Testarossa,
You need to start your own thread before this goes any further.
XXX
Testarossa214 (01-05-2012)
Laying cement board on top of leveling concrete. dswenson Flooring 3 01-04-2012 07:26 PM
bathtub vs. cement board for tile amakarevic Flooring 6 11-14-2011 06:46 PM
Remodeling bathroom - question regarding cement board prontocruz Building & Construction 2 06-27-2011 06:11 PM
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 08:29 PM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
