Best Time To Refinish Hardwood Floor During Remodel? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 11:44 AM   #1
Rewards Points: 27
Best time to refinish hardwood floor during remodel?
I'm currently in the process of completely remodeling my living room. The entire room, along with the hallway, has a hardwood floor, which I'll be refinishing.
As you can see from the photo, demolition has been completed. And since this is the first time I've refinished a floor, my question is regarding when to do the various sanding/staining/finishing steps during the remodel. Should all this be done before drywall goes up, after drywall has been mudded, after final painting, etc.??
sbazzle is offline   Reply With Quote
Old 05-16-2011, 06:20 PM   #2
DIY staff
Rewards Points: 7,174
Finishing the floor is last----almost.
Prime and paint the first coat--do not install base moldings or shoe (or door casings) --then finish the floor--then add the moldings and the final coat of paint.
It to easy to spatter a bit of finish on the walls or bump the walls or trim with the sanding machines for you to do the final paint before the floors.--Mike--
How much time to allow to refinish hardwood? skipjack Flooring 1 11-14-2008 02:51 PM
Refinishing hardwood floor questions of -time etc. 4just1don Flooring 2 10-14-2008 12:52 PM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 07:06 AM
Questions on Staining Hardwood! noodlesalad Flooring 2 12-15-2006 09:17 AM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 05:45 PM
