Best Sound-reducing underlayment for floating floors?
For Laminate floating floors in a townhome, what is the best type of sound reducing underlay? I have seen many types - cork, rubber, air-filled. What is the best type (and most cost effective) to reduce sound transmission to neighbors and give the laminate the best feel underfoot (less hollow sound)?
Also I am in California so any material has to pass CA fire ratings. |
Yes I know about the vapor barrier, most of these underlayments have attached vapor barrier and if not you can buy a separate sheet cheap. I am specifically asking about the best type underlayment to reduce sound inside the home and to the side neighbors ie cork, rubber, felt.
Not sure what you are talking about with a second floor, this is a townhouse 2 levels the bedrooms are upstairs living areas down. There is no one else living below us, I just want to minimize sound to the side neighbors and for our own comfort. I was also considering floating vinyl planks but there seem to be a lot more mixed reports on them and I tried out some samples, they scuff very easy while the laminate is practically impervious. |
If the neighbors next door to you can hear you walking around on laminate then that's a hole different story.
There is no firewall dividing the town houses? If you add extra padding vapor barrier your laminate will be to flexible, you will always hear foot steps with shoes on. If you go with a 12mm grade laminate it will be sturdier sound. |
To ansewer your question cork would work best, but it's not cheap.
You would be far better off and increace the value of the home and have a quiter floor using engineered flooring not laminite. |
Actually cork is not that expensive and you can get it in different thicknesses.:thumbsup:
http://www.lumberliquidators.com/ll/...D%20H/10015924 http://www.homedepot.com/Flooring-La...&storeId=10051 joecaption I am not looking for resale value I just want something to replace the carpet on a budget, something I can easily put down myself. Every time I post a question about budget flooring I get this response to get engineered wood. Please don't suggest more expensive floors - it is out of the budget! |
good point about the thicker laminate. |
I also prefer cork. It has great sound deadening qualities and the floor will feel solid when walked on.
Sounds like cork is the winner, then! I can get cork with an attached vapor barrier, seems like a good option for all around use. it says to tape the seams with polyethylene tape to make the vapor barrier waterproof. I live in a pretty dry climate anyway.
Reading the Armstrong laminate floor install instructions, it says to lay directly over concrete (over vapor barrier and underlay) and NOT over a plywood subfloor or subfloor on sleepers. I am surprised I thought a plywood subfloor would be better? The foundation is concrete slab but there are definitely plywood subfloors under the carpet, how do I know what's under that and whether it is suitable for installation? I would have thought putting down the vapor barrier would be enough, the floors at are ground level and above, no basements. So would I have to pull up the subfloor too and apply directly to concrete? In fact I looked at the Armstrong Luxe Plank Vinyl plank floors install instructions and it says the same thing - but everyone here has reported such problems with Allure etc over concrete! |
Shaw makes a SilentStep Ultra 3 in 1 Laminate Underlayment that helps deaden a lot of the sound under floating floors. It also provides the moisture barrier. "Superior performance acoustical flooring underlayment with unsurpassed sound absorption properties." "Impact Insulation Class rating of 72dB and Sound Transmission Class rating of 72dB". http://www.flooring-nc.com/
| All times are GMT -4. The time now is 12:08 AM. |
